Datasheet Wago 2010 — Даташит
Производитель | Wago |
Серия | 2010 |
Купить 2010-100 на РадиоЛоцман.Цены — от 0.40 до 26 400 ₽ 20 предложений от 17 поставщиков Power Metal Strip?® Resistors, Low Value (down to 0.001 ?©), Surface Mount | |||
RC2010JK-07100RL (CR-0AJL4-100R) 2010-100 Ом 5% Viking | 0.40 ₽ | ||
RC2010JK-07100KL (RS-10K104JT) 2010-100 кОм 5% Fenghua | 1.00 ₽ | ||
201-0100-01 | от 189 ₽ | ||
2010-100K | по запросу |
Parameters / Models | 2010-100 | 2010-115 | 2010-1201 | 2010-1202 | 2010-1204 | 2010-1205 | 2010-1206 | 2010-1207 | 2010-1208 | 2010-1209 | 2010-1291 | 2010-1292 | 2010-1301 | 2010-1302 | 2010-1303 | 2010-1304 | 2010-1305 | 2010-1306 | 2010-1307 | 2010-1309 | 2010-1391 | 2010-1392 | 2010-402 | 2010-403 | 2010-404 | 2010-405 | 2010-405/011-000 | 2010-433 | 2010-434 | 2010-435 | 2010-511 | 2010-549 |
Actuation type, Operating tool | Open Tool Slot | Open Tool Slot | Open Tool Slot | Open Tool Slot | Push-in | Open Tool Slot | Open Tool Slot | Push-in | Open Tool Slot | Open Tool Slot | Open Tool Slot | Open Tool Slot | Push-in | Push-in | Open Tool Slot | Push-in | ||||||||||||||||
Цвет | yellow | yellow | gray | orange | blue | black | yellow | green-yellow | white | light gray | gray | orange | gray | orange | red | blue | black | yellow | green-yellow | light gray | gray | orange | light gray | light gray | light gray | light gray | light gray | light gray | light gray | light gray | gray | gray |
Connectable conductor materials | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | ||||||||||||||||
Connection technology | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | |||||||||||||||
Country of origin | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | CN | CN | DE | DE | DE | DE | DE | DE | DE | DE | CN | CN | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE |
Габариты: глубина | 67.8 mm / 2.669 inch | 67.8 mm / 2.669 inch | 67.8 mm / 2.669 inch | 67.8 mm / 2.669 inch | 67.8 mm / 2.669 inch | 67.8 mm / 2.669 inch | 67.8 mm / 2.669 inch | 67.8 mm / 2.669 inch | 67.2 mm / 2.646 inch | 67.2 mm / 2.646 inch | 89 mm / 3.504 inch | 89 mm / 3.504 inch | 89 mm / 3.504 inch | 89 mm / 3.504 inch | 89 mm / 3.504 inch | 89 mm / 3.504 inch | 89 mm / 3.504 inch | 89 mm / 3.504 inch | 88.6 mm / 3.488 inch | 88.6 mm / 3.488 inch | 4.1 mm / 0.161 inch | 4.1 mm / 0.161 inch | 4.1 mm / 0.161 inch | 4.1 mm / 0.161 inch | 4.1 mm / 0.161 inch | 4.1 mm / 0.161 inch | 4.1 mm / 0.161 inch | 4.1 mm / 0.161 inch | ||||
Design | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | ||||||||||||||||
Fine-stranded conductor | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 6 mm² / 20 … 10 AWG | |||||||||||||||
Fine-stranded conductor with ferrule, push-in termination, from | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 14 AWG | 4 mm² / 18 AWG | |||||||||||||||
Fire load, MJ | 0.005 | 0.022 | 0.289 | 0.273 | 0.279 | 0.255 | 0.267 | 0.246 | 0.071 | 0.071 | 0.381 | 0.378 | 0.392 | 0.382 | 0.35 | 0.095 | 0.095 | 0.016 | 0.024 | 0.033 | 0.041 | 0.042 | 0.023 | 0.029 | 0.035 | 0.084 | 0.069 | |||||
GTIN | 4045454338404 | 4044918498203 | 4017332076005 | 4017332076111 | 4017332076166 | 4050821809227 | 4055143645911 | 4017332076180 | 4050821189138 | 4055143645898 | 4044918144148 | 4044918271745 | 4017332011341 | 4017332076197 | 4050821514763 | 4017332076234 | 4055143645881 | 4055143645386 | 4017332076340 | 4055143645393 | 4044918271752 | 4044918271769 | 4044918558174 | 4044918558792 | 4055143701976 | 4055143701990 | 4055143702515 | 4044918592161 | 4044918578691 | 4044918592178 | 4050821263722 | 4050821263753 |
Height | 33.5 mm / 1.319 inch | 33.5 mm / 1.319 inch | 33.5 mm / 1.319 inch | 33.5 mm / 1.319 inch | 23 mm / 0.906 inch | 23 mm / 0.906 inch | 23 mm / 0.906 inch | 23 mm / 0.906 inch | 23 mm / 0.906 inch | 23 mm / 0.906 inch | 23 mm / 0.906 inch | 23 mm / 0.906 inch | ||||||||||||||||||||
Height from upper-edge of DIN-35 rail | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | 36.9 mm / 1.453 inch | ||||||||||||||||
Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | |||||||||||||||
Marking level | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | ||||||||||||||
Nominal cross section | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 10 mm² | 4 mm² | |||||||||||||||
Number of Poles | 1 | |||||||||||||||||||||||||||||||
Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | ||||||||||||||||
Packaging type | BOX | bag | bag | bag | ||||||||||||||||||||||||||||
Product Group | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | 22 (TOPJOB S) | ||||||
Rated current, A | 32 | |||||||||||||||||||||||||||||||
Rated current (Ex e II), A | 51 | 51 | 51 | 51 | 51 | 51 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | ||||||||||||
Rated current CSA (Use Group B), A | 65 | |||||||||||||||||||||||||||||||
Rated current CSA (Use Group C), A | 65 | |||||||||||||||||||||||||||||||
Rated impulse voltage (III / 3), kV | 8 | 6 | ||||||||||||||||||||||||||||||
Rated voltage (III / 3), В | 800 | 500 | ||||||||||||||||||||||||||||||
Rated voltage CSA (Use Group B), В | 600 | |||||||||||||||||||||||||||||||
Rated voltage CSA (Use Group C), В | 600 | |||||||||||||||||||||||||||||||
Rated voltage EN (Ex e II), В | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | 550 | |||||||||||||||||||
Solid conductor | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 16 mm² / 20 … 6 AWG | 0.5 … 6 mm² / 20 … 10 AWG | |||||||||||||||
Solid conductor, push-in termination | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 16 mm² / 14 … 6 AWG | 4 … 6 mm² / 14 … 10 AWG | |||||||||||||||
Strip length | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 17 … 19 mm / 0.67 … 0.75 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | |||||||||||||||
Total number of connection points | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 1 | |||||||||||||||
Total number of potentials | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |||||||||||||||
Type of mounting | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | ||||||||||||||||
Type of wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Side-entry wiring | |||||||||||||||
Вес, г | 0.18 | 0.7 | 17.112 | 17.246 | 17.336 | 16.056 | 18.227 | 30.1 | 28.449 | 18.227 | 2.36 | 2.36 | 24.7 | 23.314 | 23.774 | 23.734 | 23.455 | 23.455 | 35.634 | 23.455 | 3.17 | 3.17 | 3.7 | 5.88 | 7.96 | 9.97 | 8.53 | 4.95 | 6.15 | 7.34 | 4.895 | 2.29 |
Ширина | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 1 mm / 0.039 inch | 1 mm / 0.039 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch | 1 mm / 0.039 inch | 1 mm / 0.039 inch | 17.5 mm / 0.689 inch | 27.5 mm / 1.083 inch | 37.6 mm / 1.48 inch | 47.6 mm / 1.874 inch | 47.6 mm / 1.874 inch | 27.5 mm / 1.083 inch | 37.6 mm / 1.48 inch | 47.6 mm / 1.874 inch | 10 mm / 0.394 inch | 10 mm / 0.394 inch |
Серия: 2010 (32)
- 2010-100 2010-115 2010-1201 2010-1202 2010-1204 2010-1205 2010-1206 2010-1207 2010-1208 2010-1209 2010-1291 2010-1292 2010-1301 2010-1302 2010-1303 2010-1304 2010-1305 2010-1306 2010-1307 2010-1309 2010-1391 2010-1392 2010-402 2010-403 2010-404 2010-405 2010-405/011-000 2010-433 2010-434 2010-435 2010-511 2010-549
