Datasheet Wago 270 — Даташит
Производитель | Wago |
Серия | 270 |
Купить 270-319 на РадиоЛоцман.Цены — от 77 до 7.00 ₽ 5 предложений от 5 поставщиков Торцевая пластина, 1 мм, серая | |||
270-319 Wago Оф. дистрибьютор | 77 ₽ | ||
270-319 Wago | 123 ₽ | ||
270-319 Wago | 234 ₽ | ||
1110-27-0319 | по запросу |
Parameters / Models | 270-319 | 270-320 | 270-321 | 270-322 | 270-409 | 270-417 | 270-480 | 270-560 | 270-560/281-434 | 270-560/281-507 | 270-564 | 270-564/281-483 | 270-570 | 270-570/281-434 | 270-570/281-507 | 270-572 | 270-572/281-434 | 270-574 | 270-574/281-483 | 270-577 | 270-585 | 270-585/281-507 | 270-586 |
Actuation type | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | Operating tool | |||||||
Цвет | gray | gray | orange | orange | silver-colored | silver-colored | silver-colored | gray | gray | gray | orange | orange | gray | gray | gray | gray | gray | orange | orange | orange | gray | gray | orange |
Connectable conductor materials | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | |||||||
Connection technology | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | |||||||
Country of origin | DE | DE | DE | DE | DE | DE | DE | CN | CN | CN | CN | CN | CN | CN | DE | CN | CN | CN | CN | CN | CN | CN | CN |
Габариты: глубина | 68 mm / 2.677 inch | 83 mm / 3.268 inch | 68 mm / 2.677 inch | 83 mm / 3.268 inch | 2.5 mm / 0.098 inch | 2.5 mm / 0.098 inch | 68 mm / 2.677 inch | 68 mm / 2.677 inch | 68 mm / 2.677 inch | 68 mm / 2.677 inch | 68 mm / 2.677 inch | 83 mm / 3.268 inch | 83 mm / 3.268 inch | 83 mm / 3.268 inch | 68 mm / 2.677 inch | 68 mm / 2.677 inch | 83 mm / 3.268 inch | 83 mm / 3.268 inch | 68 mm / 2.677 inch | 68 mm / 2.677 inch | 68 mm / 2.677 inch | 68 mm / 2.677 inch | |
Design | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | |||||||
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | |||||||
Fire load, MJ | 0.072 | 0.085 | 0.071 | 0.114 | 0.172 | 0.178 | 0.179 | 1.372 | 1.376 | 0.201 | 0.207 | 0.211 | 0.172 | 0.178 | 1.401 | 1.405 | 0.172 | 0.172 | 0.179 | 0.172 | |||
GTIN | 4017332696999 | 4017332706032 | 4017332696982 | 4017332706049 | 4045454223908 | 4045454223953 | 4045454224042 | 4050821035251 | 4050821286493 | 4045454193751 | 4045454193768 | 4045454365646 | 4050821035305 | 4050821283263 | 4045454193782 | 4050821035268 | 4050821286592 | 4045454193829 | 4045454365653 | 4050821035275 | 4050821035282 | 4045454193836 | 4050821035299 |
Height | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | |||||||||||||||||||
Height from upper-edge of DIN-35 rail | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | 39 mm / 1.535 inch | |||||||
Legend (ratings) | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | |||||||||||||||
Marking level | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | Side marking | |||||||
Nominal voltage, В | 24 | 24 | 24 | 24 | 24 | 24 | 24 | 24 | |||||||||||||||
Number of levels | 3 | 3 | 3 | 3 | 3 | 4 | 4 | 4 | 3 | 3 | 4 | 4 | 3 | 3 | 3 | 3 | |||||||
Product Group | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | 1 (Rail Mounted Terminal Blocks) | |||
Rated current, A | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | 18 | ||||||||||||
Rated impulse voltage (III / 3), kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | |||||||||||||||
Rated voltage (III / 3), В | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | |||||||||||||||
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | 0.08 … 2.5 mm² / 28 … 12 AWG | |||||||
Strip length | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | 6 … 7 mm / 0.24 … 0.28 Inch | |||||||
Total number of connection points | 4 | 4 | 4 | 4 | 4 | 5 | 5 | 5 | 4 | 4 | 5 | 5 | 4 | 4 | 4 | 4 | |||||||
Total number of potentials | 3 | 3 | 3 | 2 | 3 | 4 | 4 | 4 | 3 | 3 | 3 | 4 | 3 | 3 | 3 | 3 | |||||||
Type of mounting | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | |||||||
Type of wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | |||||||
Voltage type (1) | DC | DC | DC | DC | DC | DC | DC | DC | |||||||||||||||
Вес, г | 2.4 | 2.835 | 2.4 | 2.835 | 1.6 | 3 | 13.94 | 8.817 | 10.065 | 9.16 | 9.29 | 9.68 | 10.484 | 10 | 12.064 | 8.817 | 10.027 | 11.03 | 11.51 | 8.276 | 8.817 | 9.11 | 8.7 |
Ширина | 1 mm / 0.039 inch | 1 mm / 0.039 inch | 1 mm / 0.039 inch | 1 mm / 0.039 inch | 44 mm / 1.732 inch | 84 mm / 3.307 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch | 5 mm / 0.197 inch |
Серия: 270 (23)
