Datasheet Wago 783 — Даташит
Серия783
Datasheet Wago 783
Торцевая пластина, оранжевая
Контест
66 ₽
Industrial Module
7.00 ₽
783-317
Оф. дистрибьютор
80 ₽
783-317
Parameters / Models783-317
783-317
783-321
783-321
783-601
783-601
783-604
783-604
783-607
783-607
783-607/999-950
783-607/999-950
783-623
783-623
783-992
783-992
Abmessungen B x H x T (inch), дюйм(0.059 x 1.713 x 3.48)
Abmessungen B x H x T (mm), мм(1.5 x 43.5 x 88.4)
Actuation typeOperating toolOperating toolOperating toolOperating toolOperating toolOperating tool
Цветorangebluegraybluegreen-yellowgreen-yellowgraylight gray
Connectable conductor materialsCopperCopperCopperCopperCopperCopper
Connection technologyCAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®
Country of originCNDEDEDEDEDEPLDE
Габариты: глубина88.4 mm / 3.48 inch88.4 mm / 3.48 inch88.5 mm / 3.484 inch88.5 mm / 3.484 inch88.5 mm / 3.484 inch88.5 mm / 3.484 inch88.5 mm / 3.484 inch88.5 mm / 3.484 inch
Designangledangledangledangledangledangled
Fine-stranded conductor0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG
Fire load, MJ0.1320.1760.4740.4890.4570.4570.489
GTIN40173322876234017332287630404491858238440449185824074045454084738404545409276440449186914754017332627313
Height43.5 mm / 1.713 inch43.5 mm / 1.713 inch
Height from upper-edge of DIN-35 rail43.5 mm / 1.713 inch43.5 mm / 1.713 inch43.5 mm / 1.713 inch43.5 mm / 1.713 inch43.5 mm / 1.713 inch43.5 mm / 1.713 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Main product functionMounting Accessories
Marking levelCenter markingCenter markingCenter markingCenter markingCenter markingCenter marking
Number of levels111111
Product Group17 (TOP JOB installation terminal blocks)17 (TOP JOB installation terminal blocks)17 (TOP JOB installation terminal blocks)17 (TOP JOB installation terminal blocks)17 (TOP JOB installation terminal blocks)
Rated current, A767668
Rated impulse voltage (III / 3), kV886
Rated voltage (III / 3), В10001000400
Rated voltage EN (Ex e II), В750
Solid conductor0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG0.2 … 16 mm² / 24 … 6 AWG
Strip length16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch16 … 17 mm / 0.63 … 0.67 Inch
Total number of connection points222212
Total number of potentials111111
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Type of wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiring
Вес, г4.45.8731.69432.20445.245.243.51832.204
Ширина1.5 mm / 0.059 inch1.5 mm / 0.059 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch12 mm / 0.472 inch
На английском языке: Datasheet Wago 783
