Datasheet Wago 2204 — Даташит
Производитель | Wago |
Серия | 2204 |
high Current Toroid Inductors | |||
2204-1201 | 413 ₽ | ||
22041201 | по запросу | ||
2-2041201-4 TE Connectivity | по запросу |
Parameters / Models | 2204-1201 | 2204-1204 | 2204-1207 | 2204-1301 | 2204-1304 | 2204-1307 | 2204-1401 | 2204-1404 | 2204-1407 |
Actuation type | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button |
Цвет | gray | blue | green-yellow | gray | blue | green-yellow | gray | blue | green-yellow |
Connectable conductor materials | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper |
Connection technology | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® |
Country of origin | DE | DE | DE | DE | DE | DE | DE | DE | DE |
Габариты: глубина | 52.3 mm / 2.059 inch | 52.3 mm / 2.059 inch | 52.3 mm / 2.059 inch | 65.5 mm / 2.579 inch | 65.5 mm / 2.579 inch | 65.5 mm / 2.579 inch | 78.7 mm / 3.098 inch | 78.7 mm / 3.098 inch | 78.7 mm / 3.098 inch |
Design | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal |
Fine-stranded conductor | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG |
GTIN | 4055143711494 | 4055143711470 | 4055143711456 | 4055143711432 | 4055143711418 | 4055143711395 | 4055143711371 | 4055143711357 | 4055143711333 |
Height from upper-edge of DIN-35 rail | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch |
Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) |
Legend (ratings) | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | |||
Marking level | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking |
Nominal cross section | 4 mm² | 4 mm² | 4 mm² | 4 mm² | 4 mm² | 4 mm² | 4 mm² | 4 mm² | 4 mm² |
Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Packaging type | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX |
Rated current, A | 32 | 32 | 32 | 32 | 32 | 32 | |||
Rated current (2), A | 41 | 41 | 41 | 41 | 41 | 41 | |||
Rated impulse voltage (III / 3), kV | 8 | 8 | 8 | 8 | 8 | 8 | |||
Rated voltage (III / 3), В | 800 | 800 | 800 | 800 | 800 | 800 | |||
Solid conductor | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG | 0.5 … 6 mm² / 20 … 10 AWG |
Solid conductor, push-in termination | 1 … 6 mm² / 14 … 10 AWG | 1 … 6 mm² / 14 … 10 AWG | 1 … 6 mm² / 14 … 10 AWG | 1 … 6 mm² / 14 … 10 AWG | 1 … 6 mm² / 14 … 10 AWG | 1 … 6 mm² / 14 … 10 AWG | 1 … 6 mm² / 14 … 10 AWG | 1 … 6 mm² / 14 … 10 AWG | 1 … 6 mm² / 14 … 10 AWG |
Strip length | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch | 11 … 13 mm / 0.43 … 0.51 Inch |
Total number of connection points | 2 | 2 | 2 | 3 | 3 | 3 | 4 | 4 | 4 |
Total number of potentials | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Type of mounting | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail |
Type of wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring |
Вес, г | 7.239 | 7.239 | 12.259 | 9.161 | 9.161 | 14.071 | 11.294 | 11.294 | 16.084 |
Ширина | 6.2 mm / 0.244 inch | 6.2 mm / 0.244 inch | 6.2 mm / 0.244 inch | 6.2 mm / 0.244 inch | 6.2 mm / 0.244 inch | 6.2 mm / 0.244 inch | 6.2 mm / 0.244 inch | 6.2 mm / 0.244 inch | 6.2 mm / 0.244 inch |
Серия: 2204 (9)
