Datasheet Wago 2201 — Даташит
Производитель | Wago |
Серия | 2201 |
Купить 2201-1201 на РадиоЛоцман.Цены — от 68 до 139 ₽ 7 предложений от 2 поставщиков Клеммная колодка на DIN рейку, 2 вывод(-ов), 22 AWG, 14 AWG, 1.5 мм², Вставной, 18 А | |||
2201-1201 Wago | 68 ₽ | ||
2201-1201 Wago | от 139 ₽ |
Parameters / Models | 2201-1201 | 2201-1204 | 2201-1207 | 2201-1301 | 2201-1304 | 2201-1307 | 2201-1401 | 2201-1404 | 2201-1407 |
Actuation type | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button | Push-button |
Цвет | gray | blue | green-yellow | gray | blue | green-yellow | gray | blue | green-yellow |
Connectable conductor materials | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper | Copper |
Connection technology | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® | Push-in CAGE CLAMP® |
Country of origin | DE | DE | DE | DE | DE | DE | DE | DE | DE |
Габариты: глубина | 48.5 mm / 1.909 inch | 48.5 mm / 1.909 inch | 50.8 mm / 2 inch | 59.2 mm / 2.33 inch | 59.2 mm / 2.33 inch | 59.2 mm / 2.33 inch | 69.9 mm / 2.752 inch | 69.9 mm / 2.752 inch | 69.9 mm / 2.752 inch |
Design | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal | horizontal |
Fine-stranded conductor | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG | 0.75 mm² / 18 AWG |
GTIN | 4055143695152 | 4055143694667 | 4055143694674 | 4055143696791 | 4055143696814 | 4055143696838 | 4055143696852 | 4055143696876 | 4055143695183 |
Height from upper-edge of DIN-35 rail | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch | 32.9 mm / 1.295 inch |
Insulating material | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) | Polyamide 66 (PA 66) |
Legend (ratings) | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | (III / 3) ≙ Overvoltage category III / Pollution degree 3 | |||
Marking level | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking | Center/side marking |
Nominal cross section | 1.5 mm² | 1.5 mm² | 1.5 mm² | 1.5 mm² | 1.5 mm² | 1.5 mm² | 1.5 mm² | 1.5 mm² | 1.5 mm² |
Number of levels | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Packaging type | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX | BOX |
Rated current, A | 18 | 18 | 18 | 18 | 18 | 18 | |||
Rated current (2), A | 24 | 24 | 24 | 24 | 24 | 24 | |||
Rated impulse voltage (III / 3), kV | 8 | 8 | 8 | 8 | 8 | 8 | |||
Rated voltage (III / 3), В | 800 | 800 | 800 | 800 | 800 | 800 | |||
Solid conductor | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG | 0.25 … 2.5 mm² / 22 … 14 AWG |
Solid conductor, push-in termination | 0.75 … 2.5 mm² / 18 … 14 AWG | 0.75 … 2.5 mm² / 18 … 14 AWG | 0.75 … 2.5 mm² / 18 … 14 AWG | 0.75 … 2.5 mm² / 18 … 14 AWG | 0.75 … 2.5 mm² / 18 … 14 AWG | 0.75 … 2.5 mm² / 18 … 14 AWG | 0.75 … 2.5 mm² / 18 … 14 AWG | 0.75 … 2.5 mm² / 18 … 14 AWG | 0.75 … 2.5 mm² / 18 … 14 AWG |
Strip length | 9 … 11 mm / 0.35 … 0.43 Inch | 9 … 11 mm / 0.35 … 0.43 Inch | 9 … 11 mm / 0.35 … 0.43 Inch | 9 … 11 mm / 0.35 … 0.43 Inch | 9 … 11 mm / 0.35 … 0.43 Inch | 9 … 11 mm / 0.35 … 0.43 Inch | 9 … 11 mm / 0.35 … 0.43 Inch | 9 … 11 mm / 0.35 … 0.43 Inch | 9 … 11 mm / 0.35 … 0.43 Inch |
Total number of connection points | 2 | 2 | 2 | 3 | 3 | 3 | 4 | 4 | 4 |
Total number of potentials | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Type of mounting | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail |
Type of wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring | Front-entry wiring |
Вес, г | 4.145 | 4.145 | 7.005 | 5.03 | 5.03 | 7.89 | 6.101 | 6.101 | 9.021 |
Ширина | 4.2 mm / 0.165 inch | 4.2 mm / 0.165 inch | 4.2 mm / 0.165 inch | 4.2 mm / 0.165 inch | 4.2 mm / 0.165 inch | 4.2 mm / 0.165 inch | 4.2 mm / 0.165 inch | 4.2 mm / 0.165 inch | 4.2 mm / 0.165 inch |
Серия: 2201 (9)
