Datasheet Wago 2200 — Даташит
Серия2200
Datasheet Wago 2200
8 предложений от 3 поставщиков
Клеммная колодка на DIN рейку, 2 вывод(-ов), 24 AWG, 16 AWG, 1 мм², Вставной, 13.5 А
28 ₽
2200-1201
от 139 ₽
Industrial Module
36 ₽
Parameters / Models2200-1201
2200-1201
2200-1204
2200-1204
2200-1207
2200-1207
2200-1301
2200-1301
2200-1304
2200-1304
2200-1307
2200-1307
2200-1401
2200-1401
2200-1404
2200-1404
2200-1407
2200-1407
Actuation typePush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-button
Цветgraybluegreen-yellowgraybluegreen-yellowgraybluegreen-yellow
Connectable conductor materialsCopperCopperCopperCopperCopperCopperCopperCopperCopper
Connection technologyPush-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®
Country of originDEDEDEDEDEDEDEDEDE
Габариты: глубина48.5 mm / 1.909 inch48.5 mm / 1.909 inch50.8 mm / 2 inch58.2 mm / 2.291 inch58.2 mm / 2.291 inch58.2 mm / 2.291 inch67.9 mm / 2.673 inch67.9 mm / 2.673 inch67.9 mm / 2.673 inch
Designhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontalhorizontal
Fine-stranded conductor0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.5 mm² / 20 AWG0.5 mm² / 20 AWG0.5 mm² / 20 AWG0.5 mm² / 20 AWG0.5 mm² / 20 AWG0.5 mm² / 20 AWG0.5 mm² / 20 AWG0.5 mm² / 20 AWG0.5 mm² / 20 AWG
GTIN405514369154340551436915814055143691604405514369161140551436916284055143692007405514369173440551436916354055143692014
Height from upper-edge of DIN-35 rail32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch32.9 mm / 1.295 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Marking levelCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side marking
Nominal cross section1 mm²1 mm²1 mm²1 mm²1 mm²1 mm²1 mm²1 mm²1 mm²
Number of levels111111111
Packaging typeBOXBOXBOXBOXBOXBOXBOXBOXBOX
Rated current, A13.513.513.513.513.513.5
Rated current (2), A181818181818
Rated impulse voltage (III / 3), kV888888
Rated voltage (III / 3), В800800800800800800
Solid conductor0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor, push-in termination0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch9 … 11 mm / 0.35 … 0.43 Inch
Total number of connection points222333444
Total number of potentials111111111
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Type of wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiring
Вес, г3.5043.5045.9024.1664.1666.6644.8884.8887.586
Ширина3.5 mm / 0.138 inch3.5 mm / 0.138 inch3.5 mm / 0.138 inch3.5 mm / 0.138 inch3.5 mm / 0.138 inch3.5 mm / 0.138 inch3.5 mm / 0.138 inch3.5 mm / 0.138 inch3.5 mm / 0.138 inch
На английском языке: Datasheet Wago 2200
