Datasheet Wago 2210-1307 — Даташит
TOPJOB S ground terminal block with Push-buttons; rail mount; 3-conductor; 10 mm wide; green-yellow
Купить 2210-1307 на РадиоЛоцман.Цены — от 371 до 48 974 ₽ 10 предложений от 5 поставщиков Клеммная колодка на DIN рейку, 3 вывод(-ов), 20 AWG, 6 AWG, 10 мм², Вставной, 57 А | |||
2210-1307 Wago | 371 ₽ | ||
2210-1307 | 1 176 ₽ | ||
2210-1307 Wago | 78 ₽ | ||
22101307 | 48 974 ₽ |
Actuation type | Push-button |
Цвет | green-yellow |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 89 mm / 3.504 inch |
Design | horizontal |
Fine-stranded conductor | 0.5 … 16 mm² / 20 … 6 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 2.5 mm² / 14 AWG |
GTIN | 4055143736138 |
Height from upper-edge of DIN-35 rail | 36.9 mm / 1.453 inch |
Marking level | Center/side marking |
Nominal cross section | 10 mm² |
Number of levels | 1 |
Packaging type | BOX |
Solid conductor | 0.5 … 16 mm² / 20 … 6 AWG |
Solid conductor, push-in termination | 2.5 … 16 mm² / 14 … 6 AWG |
Strip length | 17 … 19 mm / 0.67 … 0.75 Inch |
Total number of connection points | 3 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 37.525 г |
Ширина | 10 mm / 0.394 inch |
22101307, 2210 1307
