Datasheet Wago 2210-1204 — Даташит
TOPJOB S feedthrough terminal block with Push-buttons; rail mount; 2-conductor; 10 mm wide; blue
Купить 2210-1204 на РадиоЛоцман.Цены — от 2 426 до 460 ₽ 9 предложений от 4 поставщиков Клеммная колодка на DIN рейку, 2 вывод(-ов), 20 AWG, 6 AWG, 10 мм², Вставной, 57 А | |||
2210-1204 Wago | 2 426 ₽ | ||
2210-1204 Wago | 26 ₽ | ||
2210-1204 Wago | 188 ₽ | ||
2210-1204 Wago | от 460 ₽ |
Actuation type | Push-button |
Цвет | blue |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 67.6 mm / 2.661 inch |
Design | horizontal |
Fine-stranded conductor | 0.5 … 16 mm² / 20 … 6 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 2.5 mm² / 14 AWG |
GTIN | 4055143736077 |
Height from upper-edge of DIN-35 rail | 36.9 mm / 1.453 inch |
Marking level | Center/side marking |
Nominal cross section | 10 mm² |
Number of levels | 1 |
Packaging type | BOX |
Rated current | 57 A |
Rated current (2) | 76 A |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 3) | 800 В |
Solid conductor | 0.5 … 16 mm² / 20 … 6 AWG |
Solid conductor, push-in termination | 2.5 … 16 mm² / 14 … 6 AWG |
Strip length | 17 … 19 mm / 0.67 … 0.75 Inch |
Total number of connection points | 2 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 18.975 г |
Ширина | 10 mm / 0.394 inch |
22101204, 2210 1204
