HRP-N3 - серия источников питания с максимальной пиковой мощностью в 350% от MEAN WELL
Datasheet Wago 2002-2703 — Даташит
Серия2002
Модель2002-2703
Double-deck terminal block; Through/through terminal block; L/N; without marker carrier; suitable for Ex e II applications; Blue conductor entry upper deck; for DIN-rail 35 x 15 and 35 x 7.5; 2.5 mm²; Push-in CAGE CLAMP
Double-deck terminal block Through/through terminal block L/N, gray (50 шт)
Industrial Module
66 ₽
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
Actuation typePush-in Operating tool
Цветgray
Country of originDE
Габариты: глубина92.5 mm / 3.642 inch
Designhorizontal
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
GTIN4055143622516
Height from upper-edge of DIN-35 rail51.7 mm / 2.035 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of connection points2
Number of connection points (connection type)2
Number of levels2
Potential markingL/N
Rated current24 A
Rated current (2)28 A
Rated voltage (III / 3)800 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points4
Total number of potentials2
Type of mountingDIN-35 rail
Вес12.532 г
Ширина5.2 mm / 0.205 inch
20022703, 2002 2703
На английском языке: Datasheet Wago 2002-2703
