Datasheet Wago 2002-1711/1000-542 — Даташит
Серия2002
Модель2002-1711/1000-542
TOPJOB S fuse disconnect terminal block; with pivoting fuse holder for 5 x 20 mm fuse; with blown fuse LED indication for 30 - 65 V; rail mount; 3-conductor; 6.2 mm wide; gray
Industrial Module
2002-1711/1000-542
335 ₽
Электромеханические реле Hongfa – надежность и качество 19 января 2023
Actuation typeOpen Tool Slot
Цветgray
Country of originCN
Габариты: глубина76.8 mm / 3.024 inch
Designhorizontal
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.314 MJ
GTIN4050821707622
Height from upper-edge of DIN-35 rail57.6 mm / 2.268 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of levels1
Rated current6.3 A
Rated voltage (III / 3)250 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points3
Total number of potentials1
Type of mountingDIN-35 rail
Вес15.012 г
Ширина6.2 mm / 0.244 inch
20021711/1000542, 2002 1711/1000 542
На английском языке: Datasheet Wago 2002-1711/1000-542
