Datasheet Wago 286 — Даташит
Производитель | Wago |
Серия | 286 |
Модуль ограничителя перенапряжений 2 каскада | |||
286-831 Wago Оф. дистрибьютор | 16 672 ₽ | ||
IAGN11-28683-1 | по запросу | ||
286-831 Wago | по запросу | ||
Parameters / Models | 286-831 | 286-832 | 286-833 | 286-834 | 286-834/024-000 | 286-835 | 286-835/115-000 | 286-836 | 286-838 | 286-841 | 286-842 | 286-843 | 286-844 |
Цвет | gray | gray | gray | gray | gray | grey | gray | gray | gray | gray | gray | gray | gray |
Connection technology | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | CAGE CLAMP® | |||||||||
Country of origin | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE | DE |
Габариты: глубина | 52 mm / 1.654 inch | 52 mm / 1.654 inch | 52 mm / 1.654 inch | 52 mm / 1.654 inch | 52 mm / 1.654 inch | 73 mm / 2.87 inch | 73 mm / 2.87 inch | 73 mm / 2.87 inch | 73 mm / 2.87 inch | 52 mm / 1.654 inch | 52 mm / 1.654 inch | 52 mm / 1.654 inch | 52 mm / 1.654 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 14 AWG | 0.08 … 2.5 mm² / 28 … 14 AWG | 0.08 … 2.5 mm² / 28 … 14 AWG | 0.08 … 2.5 mm² / 28 … 14 AWG | |||||||||
GTIN | 4017332158213 | 4017332158220 | 4045454649784 | 4017332158244 | 4017332068123 | 4050821029083 | 4050821866435 | 4045454460136 | 4050821866459 | 4045454353292 | 4045454574543 | 4045454549855 | 4045454308087 |
Height from upper-edge of DIN-35 rail | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch | 82.5 mm / 3.25 inch |
Housing design | Pluggable module for terminal blocks | Pluggable module for terminal blocks | Pluggable module for terminal blocks | Pluggable module for terminal blocks | Pluggable module for terminal blocks | Pluggable module on terminal blocks | Pluggable module on terminal blocks | Pluggable module on terminal blocks | Pluggable module on terminal blocks | Pluggable module for terminal blocks | Pluggable module for terminal blocks | Pluggable module for terminal blocks | Pluggable module for terminal blocks |
Max. surge current line/PG | 0.5 | 0.5 | 1.5 | 1.5 | 4.5 | 4.5 | 1 | 2.5 | 1.5 | 1.5 | 1.5 | 1.5 | |
Max. surge current line/line | 1.5 | 1.5 | 5 | 4.5 | 4.5 | 1 | 2.5 | 1.5 | 1.5 | 1.5 | 1.5 | ||
Nominal current, A | 6 | 6 | 0.05 | 6 | 6 | 10 | 10 | 10 | 10 | 6 | 6 | 6 | 6 |
Nominal discharge current line/PG | 200 A | 200 A | 1.5 kA | 1.5 kA | 1 kA | 1 kA | 300 A | 1 kA | 600 A | 600 A | 600 A | 600 A | |
Nominal discharge current line/line | 1.5 kA | 1.5 kA | 5 kA | 1 kA | 1 kA | 300 A | 1 kA | 600 A | 600 A | 600 A | 600 A | ||
Nominal operating voltage | 24 V AC/DC | 24 V AC/DC | 24 VDC | 12 VDC | 24 VDC | 230 VAC | 115 VAC | 24 V AC/DC | 230 VAC | 220 VDC | 230 VAC | 115 VAC | 110 VDC |
Operating voltage | ≤ 30 VAC; ≤ 38 VDC | ≤ 30 VAC; ≤ 38 VDC | ≤ 30 VDC | ≤ 14 VDC | ≤ 30 VDC | ≤ 275 VAC | ≤ 150 VAC | ≤ 35 VAC; ≤ 45 VDC | ≤ 300 VAC | ≤ 320 VDC | ≤ 250 VAC | ≤ 140 VAC | ≤ 180 VDC |
Pollution degree | 3 | 3 | 3 | 3 | 3 | 3 | 2 | 3 | 3 | 3 | 3 | 2 | 3 |
Product Group | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) | 6 (Interface Electronics) |
Rated continuous current, A | 6 | 6 | 6 | 6 | |||||||||
Rated impulse voltage, kV | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
Rated voltage, В | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 | 250 |
Response time line/PG | ≤ 25 ns | ≤ 25 ns | ≤ 25 ns | ≤ 10 ns | ≤ 1 ms | ≤ 1 ms | ≤ 1 ms | ≤ 1 ms | ≤ 1 ms | ≤ 1 ms | ≤ 1 ms | ≤ 1 ms | |
Response time line/line | ≤ 25 ns | ≤ 5 ns | ≤ 10 ns | ≤ 25 ns | ≤ 25 ns | ≤ 25 ns | ≤ 25 ns | ≤ 25 ns | ≤ 25 ns | ≤ 25 ns | ≤ 25 ns | ||
Solid conductor | 0.08 … 2.5 mm² / 28 … 14 AWG | 0.08 … 2.5 mm² / 28 … 14 AWG | 0.08 … 2.5 mm² / 28 … 14 AWG | 0.08 … 2.5 mm² / 28 … 14 AWG | |||||||||
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | 8 … 9 mm / 0.31 … 0.35 Inch | |||||||||
Surrounding air (operating) temperature | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C | -25 … 85 °C |
Type of mounting | Pluggable module for carrier terminal blocks | Pluggable module for carrier terminal blocks | Pluggable module for carrier terminal blocks | Pluggable module for carrier terminal blocks | Pluggable module for carrier terminal blocks | DIN-35 rail | DIN-35 rail | DIN-35 rail | DIN-35 rail | Pluggable module for carrier terminal blocks | Pluggable module for carrier terminal blocks | Pluggable module for carrier terminal blocks | Pluggable module for carrier terminal blocks |
Voltage protection level line/PG | ≤ 93 V | ≤ 93 V | ≤ 22 V | ≤ 59 V | ≤ 1.3 kV | ≤ 1 kV | ≤ 700 V | ≤ 1 kV | ≤ 900 V | ≤ 900 V | ≤ 900 V | ≤ 900 V | |
Voltage protection level line/line | ≤ 93 V | ≤ 59 V | ≤ 59 V | ≤ 700 V | ≤ 400 V | ≤ 100 V | ≤ 800 V | ≤ 650 V | ≤ 650 V | ≤ 650 V | ≤ 650 V | ||
Вес, г | 32.505 | 34.505 | 36.962 | 40.9 | 41.2 | 56.9 | 55.8 | 57.2 | 55.181 | 43.2 | 47.6 | 44.872 | 42.3 |
Ширина | 20 mm / 0.787 inch | 20 mm / 0.787 inch | 20 mm / 0.787 inch | 20 mm / 0.787 inch | 20 mm / 0.787 inch | 17 mm / 0.669 inch | 17 mm / 0.669 inch | 17 mm / 0.669 inch | 17 mm / 0.669 inch | 25 mm / 0.984 inch | 25 mm / 0.984 inch | 25 mm / 0.984 inch | 25 mm / 0.984 inch |
Серия: 286 (13)
