Datasheet Wago 2002-1308 — Даташит
Shield terminal block; rail mount; 3-conductor; 5.2 mm wide; white
Купить 2002-1308 на РадиоЛоцман.Цены — от 191 до 1 702 ₽ 3-пров. экранированная клемма, 0,25 - 2,5 (4) мм2, белая | |||
2002-1308 Wago | 191 ₽ | ||
2002-1308 Wago Оф. дистрибьютор | 548 ₽ | ||
2002-1308 Wago | 1 702 ₽ |
Actuation type | Open Tool Slot |
Цвет | white |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 59.2 mm / 2.33 inch |
Design | horizontal |
Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
Fire load | 0.125 MJ |
GTIN | 4055143243919 |
Height from upper-edge of DIN-35 rail | 32.9 mm / 1.295 inch |
Marking level | Center/side marking |
Nominal cross section | 2.5 mm² |
Number of levels | 1 |
Packaging type | BOX |
Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 3 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 9.022 г |
Ширина | 5.2 mm / 0.205 inch |
Серия: 2002 (100 из 422)
- 2002-1091 2002-1092 2002-115 2002-1201 2002-1202 2002-1203 2002-1204 2002-1205 2002-1206 2002-1207 2002-1208 2002-1211/1000-410 2002-1211/1000-411 2002-1291 2002-1292 2002-1293 2002-1294 2002-1301 2002-1302 2002-1303 2002-1304 2002-1305 2002-1306 2002-1307 2002-1308 2002-1311/1000-410 2002-1311/1000-411 2002-1321/1000-413 2002-1321/1000-434 2002-1391 2002-1392 2002-1393 2002-1394 2002-1401 2002-1402 2002-1403 2002-1404 2002-1405 2002-1406 2002-1407 2002-1408 2002-1411/1000-410 2002-1411/1000-411 2002-1421/1000-413 2002-1421/1000-434 2002-1441 2002-1491 2002-1492 2002-1493 2002-1494 2002-1549 2002-1568 2002-1591 2002-1592 2002-1593 2002-1594 2002-1601 2002-1602 2002-1604 2002-1611 2002-1611/1000-541 2002-1611/1000-542 2002-1611/1000-836 2002-1611/1000-867 2002-1661 2002-1662 2002-1671 2002-1671/401-000 2002-1672 2002-1672/401-000 2002-1674 2002-1674/401-000 2002-1681 2002-1691 2002-1692 2002-1701 2002-1702 2002-1704 2002-1707 2002-171 2002-1711 2002-1711/1000-541 2002-1711/1000-542 2002-1711/1000-836 2002-1711/1000-867 2002-172 2002-1761 2002-1771 2002-1771/401-000 2002-1772 2002-1772/401-000 2002-1774 2002-1774/401-000 2002-1781 2002-1791 2002-1792 2002-1801 2002-1802 2002-1804 2002-1811
20021308, 2002 1308
