Datasheet Wago 2022-104/000-038 — Даташит
1-проводниковая розетка; 2,5 мм²; 4-пол.
Купить 2022-104/000-038 на РадиоЛоцман.Цены — от 182 до 682 ₽ 1-conductor female plug suitable for Ex nA applications with ground base module (50 шт) | |||
2022-104/000-038/999-953 Wago | 182 ₽ | ||
2022-104/000-038 Wago Оф. дистрибьютор | 682 ₽ |
Actuation type | Operating tool Push-in |
Цвет | gray, blue, green-yellow |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 22.4 mm / 0.882 inch |
Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
Fire load | 0.219 MJ |
GTIN | 4045454915575 |
Height | 40.5 mm / 1.594 inch |
Marking level | Side marking |
Nominal cross section | 2.5 mm² |
Number of Poles | 4 |
Product Group | 18 (X-COM-System) |
Rated current | 24 A |
Rated current (2) | 32 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 690 В |
Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
Total number of connection points | 4 |
Total number of potentials | 4 |
Type of wiring | Front-entry wiring |
Вес | 13.37 г |
Ширина | 20.8 mm / 0.819 inch |
Серия: 2022 (100 из 251)
- 2022-100 2022-101 2022-101/000-006 2022-101/000-012 2022-101/000-016 2022-101/122-000 2022-101/122-006 2022-101/122-016 2022-101/132-000 2022-101/132-006 2022-101/132-016 2022-101/142-000 2022-101/142-006 2022-101/142-016 2022-102 2022-102/000-006 2022-102/000-012 2022-102/000-016 2022-102/000-038 2022-102/000-039 2022-102/122-000 2022-102/132-000 2022-102/142-000 2022-102/999-953 2022-103 2022-103/000-006 2022-103/000-012 2022-103/000-016 2022-103/000-036 2022-103/000-037 2022-103/000-038 2022-103/000-038/999-953 2022-103/000-039 2022-103/000-039/999-953 2022-103/123-000 2022-103/133-000 2022-103/143-000 2022-103/999-953 2022-104 2022-104/000-006 2022-104/000-012 2022-104/000-016 2022-104/000-036 2022-104/000-037 2022-104/000-038 2022-104/000-038/999-953 2022-104/000-039 2022-104/000-039/999-953 2022-104/123-000 2022-104/133-000 2022-104/143-000 2022-104/999-953 2022-105 2022-105/000-006 2022-105/000-012 2022-105/000-016 2022-105/000-036 2022-105/000-037 2022-105/000-038 2022-105/000-038/999-953 2022-105/000-039 2022-105/000-039/999-953 2022-105/123-000 2022-105/134-000 2022-105/144-000 2022-105/999-953 2022-106 2022-106/000-006 2022-106/000-012 2022-106/000-016 2022-106/000-036 2022-106/000-037 2022-106/000-038 2022-106/000-038/999-953 2022-106/000-039 2022-106/000-039/999-953 2022-106/123-000 2022-106/134-000 2022-106/144-000 2022-106/999-953 2022-107 2022-107/000-006 2022-107/000-012 2022-107/000-016 2022-107/000-036 2022-107/000-037 2022-107/000-038 2022-107/000-039 2022-107/123-000 2022-107/135-000 2022-107/145-000 2022-107/999-953 2022-108 2022-108/000-006 2022-108/000-012 2022-108/000-016 2022-108/000-037 2022-108/000-039 2022-108/123-000 2022-108/135-000
- Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022104/000038, 2022 104/000 038
