Datasheet Wago 2002-2218/099-000 — Даташит
Серия2002
Модель2002-2218/099-000
Double-deck terminal block; shield/through (Shield/N); with gray separator; rail mount; 2-conductor; 6.2 mm wide; gray
2-уровн. клемма, 0,25 - 2,5 (4) мм2, , L/PE
Industrial Module
2002-2218/099-000
117 ₽
2002-2218/099-000
Оф. дистрибьютор
672 ₽
Электромеханические реле Hongfa – надежность и качество 19 января 2023
Actuation typeOpen Tool Slot
Цветgray
Country of originDE
Габариты: глубина69.7 mm / 2.744 inch
Designhorizontal
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.289 MJ
GTIN4050821299134
Height from upper-edge of DIN-35 rail51.7 mm / 2.035 inch
Marking levelCenter/side marking
Nominal cross section2.5 mm²
Number of connection points2
Number of connection points (connection type)2
Number of levels2
Potential markingSchirm//N
Rated current24 A
Rated voltage (III / 3)800 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points4
Total number of potentials2
Type of mountingDIN-35 rail
Вес15.92 г
Ширина6.2 mm / 0.244 inch
20022218/099000, 2002 2218/099 000
На английском языке: Datasheet Wago 2002-2218/099-000
