Datasheet Wago 738-306 — Даташит
Quadruple-deck PCB terminal block; 2.5 mm²; Pin spacing 5.08 mm; 4 x 6-pole; CAGE CLAMP
![]() 5 предложений от 5 поставщиков 4-уров. клемма для печатных плат, 4 вывода под пайку, в линию 6X4-конт., шаг 5:08 мм | |||
738-306 Wago | 1 007 ₽ | ||
738-306 Wago Оф. дистрибьютор | 2 000 ₽ | ||
738-306 Wago | по запросу | ||
738-306 | по запросу |
Цвет | orange |
Country of origin | PL |
Габариты: глубина | 37.5 mm / 1.476 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.513 MJ |
GTIN | 4045454162078 |
Height | 48.2 mm / 1.898 inch |
Height from the surface | 44.2 mm / 1.74 inch |
Material group | I |
Number of Poles | 6 |
Number of levels | 4 |
PCB contact | THT |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 18 A |
Rated current (2) | 18 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated impulse voltage (II / 2) 2 | 4 kV |
Rated impulse voltage (III / 2) 2 | 4 kV |
Rated impulse voltage (III / 3) 2 | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (II / 2) 2 | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 2) 2 | 320 В |
Rated voltage (III / 3) | 250 В |
Rated voltage (III / 3) 2 | 320 В |
Ratings according to 2 | IEC/EN 60664-1 |
Ratings note | Between the modules |
Ratings note 2 | Between the decks |
Solder pin arrangement | within the terminal block, in line |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Total number of connection points | 24 |
Total number of potentials | 24 |
Вес | 36.856 г |
Ширина | 31.48 mm / 1.239 inch |
Серия: 738 (32)
- PCB Interconnect
