Datasheet Wago 739-3209 — Даташит
PCB terminal block; 2.5 mm²; Pin spacing 10 mm; 9-pole; CAGE CLAMP
9-конт. клеммная колодка на плату, шаг 10 мм, серая | |||
739-3209 Wago Оф. дистрибьютор | 964 ₽ | ||
739-3209 | по запросу | ||
739-3209 Wago | по запросу |
Цвет | gray |
Conductor entry angle to the PCB | 90 ° |
Country of origin | CH |
Габариты: глубина | 14.3 mm / 0.563 inch |
Drilled hole diameter (tolerance) | 1.6(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.323 MJ |
GTIN | 4050821401490 |
Height | 19 mm / 0.748 inch |
Height from the surface | 15.8 mm / 0.622 inch |
Material group | I |
Number of Poles | 17 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 10 mm (0.394 inch) |
Rated current | 24 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 1000 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.8 x 1 mm |
Solder pin length | 3.2 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 9 |
Total number of potentials | 9 |
Вес | 15.446 г |
Ширина | 86.5 mm / 3.406 inch |
Серия: 739 (97)
- 739-102 739-103 739-104 739-105 739-106 739-107 739-108 739-109 739-110 739-112 739-115 739-116 739-124 739-152 739-153 739-154 739-155 739-156 739-157 739-158 739-159 739-160 739-162 739-166 739-174 739-202 739-203 739-204 739-205 739-206 739-207 739-208 739-209 739-210 739-212 739-232 739-233 739-234 739-235 739-236 739-237 739-238 739-239 739-240 739-242 739-302 739-302/001-000 739-303 739-303/001-000 739-304 739-304/001-000 739-305 739-305/001-000 739-306 739-306/001-000 739-307 739-307/001-000 739-308 739-308/001-000 739-309 739-309/001-000 739-310 739-310/001-000 739-312 739-312/001-000 739-3202 739-3203 739-3204 739-3205 739-3206 739-3207 739-3208 739-3209 739-3210 739-3211 739-3212 739-332 739-332/001-000 739-333 739-333/001-000 739-334 739-334/001-000 739-335 739-335/001-000 739-336 739-336/001-000 739-337 739-337/001-000 739-338 739-338/001-000 739-339 739-339/001-000 739-340 739-340/001-000 739-340/100-000/001-000 739-342 739-342/001-000
- PCB Interconnect
7393209, 739 3209
