Datasheet Wago 741-306 — Даташит
Through-panel PCB terminal strip; 2 solder pins/pole; 6-pole; with integrated push-buttons; pin spacing 7.5 mm / 0.295 in; gray
Разъем на печатную плату 6-пол.RM7,5 | |||
741-306 Wago Оф. дистрибьютор | 688 ₽ | ||
741-306 Wago | по запросу |
Actuation type | Push-button |
Цвет | gray |
Country of origin | CH |
Габариты: глубина | 12.8 mm / 0.504 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.191 MJ |
GTIN | 4044918680165 |
Height | 22.5 mm / 0.886 inch |
Height from the surface | 18.5 mm / 0.728 inch |
Material group | I |
Number of Poles | 6 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 400 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Total number of connection points | 6 |
Total number of potentials | 6 |
Вес | 9.668 г |
Ширина | 44 mm / 1.732 inch |
Серия: 741 (100 из 120)
- 741-100 741-102 741-103 741-104 741-105 741-106 741-107 741-108 741-109 741-110 741-112 741-116 741-132 741-133 741-134 741-135 741-136 741-137 741-138 741-139 741-140 741-142 741-146 741-202 741-203 741-204 741-205 741-206 741-207 741-208 741-209 741-210 741-212 741-216 741-232 741-233 741-234 741-235 741-236 741-237 741-238 741-239 741-240 741-242 741-246 741-302 741-303 741-304 741-305 741-306 741-307 741-308 741-309 741-310 741-322 741-323 741-324 741-325 741-326 741-327 741-328 741-329 741-330 741-402 741-403 741-404 741-405 741-406 741-407 741-408 741-409 741-410 741-422 741-423 741-424 741-425 741-426 741-427 741-428 741-429 741-430 741-502 741-503 741-504 741-505 741-506 741-507 741-508 741-522 741-523 741-524 741-525 741-526 741-527 741-528 741-600 741-602 741-603 741-604 741-605
- PCB Interconnect
