Datasheet Wago 745-854/006-000 — Даташит
Stackable PCB terminal block; 16 mm²; Pin spacing 10 mm; 1-pole; suitable for Ex-i applications; CAGE CLAMP ; commoning option
Купить 745-854/006-000 на РадиоЛоцман.Цены — от 138 до 11 982 ₽ Модульная клемма на плату, шаг 10 мм, синяя | |||
745-854/006-000 Wago | 138 ₽ | ||
745-854/006-000 Wago Оф. дистрибьютор | 228 ₽ | ||
745854006000 | 11 982 ₽ | ||
745-854/006-000 Wago | по запросу |
Цвет | blue |
Country of origin | PL |
Габариты: глубина | 33.4 mm / 1.315 inch |
Drilled hole diameter (tolerance) | 2.2(+ 0.1) мм |
Fine-stranded conductor | 0.2 … 16 mm² / 24 … 6 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 10 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 10 mm² |
Fire load | 0.126 MJ |
GTIN | 4044918303156 |
Height | 33.5 mm / 1.319 inch |
Height from the surface | 27 mm / 1.063 inch |
Material group | I |
Number of Poles | 1 |
Number of jumper slots | 1 |
Number of levels | 1 |
Number of solder pins per potential | 4 |
PCB contact | THT |
Pin spacing | 10 mm (0.394 inch) |
Rated current | 76 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 1.2 x 1.6 mm |
Solder pin length | 6.5 мм |
Solid conductor | 0.2 … 16 mm² / 24 … 6 AWG |
Strip length | 12 … 13 mm / 0.47 … 0.51 Inch |
Total number of connection points | 1 |
Total number of potentials | 1 |
Вес | 8.944 г |
Ширина | 11.5 mm / 0.453 inch |
Серия: 745 (100 из 266)
- 745-362 745-380 745-3801 745-3803 745-3803/999-950 745-3804 745-3807 745-3808 745-381 745-382 745-383 745-384 745-385 745-390 745-391 745-392 745-393 745-394 745-395 745-500 745-501/011-000 745-502/006-000 745-502/011-000 745-503/006-000 745-504/006-000 745-504/011-000 745-505/006-000 745-540 745-545 745-582 745-583 745-584 745-585 745-602/006-000 745-603/006-000 745-604/006-000 745-604/011-000 745-605/006-000 745-605/007-000 745-606/006-000 745-607/007-000 745-631 745-632 745-633 745-634 745-635 745-652/006-000 745-652/007-000 745-652/011-000 745-653/006-000 745-653/007-000 745-654/006-000 745-655/006-000 745-681 745-682 745-683 745-684 745-685 745-801 745-803 745-803/999-950 745-804 745-807 745-808 745-811 745-813 745-813/999-950 745-814 745-817 745-818 745-821 745-823 745-824 745-827 745-828 745-831 745-833 745-834 745-837 745-838 745-841 745-843 745-844 745-847 745-848 745-851/006-000 745-853/006-000 745-854/006-000 745-857/006-000 745-858/006-000 745-871/006-000 745-873/006-000 745-874/006-000 745-877/006-000 745-878/006-000 745-881/006-000 745-883/006-000 745-884/006-000 745-887/006-000 745-888/006-000
- PCB Interconnect
745854/006000, 745 854/006 000
