Datasheet Wago 745-1409 — Даташит
PCB terminal block; 6 mm²; Pin spacing 12.5 mm; 9-pole; CAGE CLAMP
9-конт. колодка для платы, шаг 12,5 мм, серая | |||
745-1409 Wago Оф. дистрибьютор | 1 827 ₽ | ||
745-1409 Wago | по запросу |
Цвет | gray |
Country of origin | PL |
Габариты: глубина | 29.1 mm / 1.146 inch |
Drilled hole diameter (tolerance) | 1.8(+ 0.1) мм |
Fine-stranded conductor | 0.2 … 6 mm² / 24 … 10 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 4 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 4 mm² |
Fire load | 1.11 MJ |
GTIN | 4045454625542 |
Height | 27.5 mm / 1.083 inch |
Height from the surface | 23 mm / 0.906 inch |
Material group | I |
Number of Poles | 9 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 12.5 mm (0.492 inch) |
Rated current | 41 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 1000 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 1 x 1.4 mm |
Solder pin length | 4.5 мм |
Solid conductor | 0.2 … 6 mm² / 24 … 10 AWG |
Strip length | 11 … 12 mm / 0.43 … 0.47 Inch |
Total number of connection points | 9 |
Total number of potentials | 9 |
Вес | 57.856 г |
Ширина | 109.1 mm / 4.295 inch |
Серия: 745 (100 из 266)
- 745-100 745-102 745-102/005-000 745-103 745-104 745-104/005-000 745-105 745-105/005-000 745-106 745-107 745-108 745-108/000-006 745-109 745-110 745-112 745-1352 745-1353 745-1353/000-006 745-1354 745-1355 745-1356 745-1357 745-1358 745-1359 745-1360 745-1362 745-140 745-1402 745-1403 745-1404 745-1405 745-1406 745-1407 745-1408 745-1409 745-1410 745-1412 745-145 745-1452 745-1453 745-1454 745-1455 745-1456 745-1457 745-1458 745-1459 745-1460 745-1462 745-152 745-152/005-000 745-153 745-153/000-006 745-154 745-154/000-006 745-155 745-156 745-157 745-157/005-000 745-158 745-159 745-160 745-162 745-180 745-181 745-182 745-183 745-184 745-185 745-190 745-191 745-192 745-193 745-194 745-195 745-202 745-202/005-000 745-203 745-204 745-204/000-023 745-205 745-206 745-207 745-208 745-209 745-210 745-212 745-280 745-281 745-283 745-284 745-285 745-300 745-302 745-302/005-000 745-303 745-303/000-016/999-950 745-303/005-000 745-304 745-304/005-000 745-305
- PCB Interconnect
7451409, 745 1409
