Datasheet Wago 745-3208 — Даташит
PCB terminal block; 4 mm²; Pin spacing 10 mm; 8-pole; CAGE CLAMP
8-конт. клеммная колодка, шаг 10 мм, серая | |||
745-3208 Wago Оф. дистрибьютор | 803 ₽ | ||
745-3208 Wago | по запросу |
Цвет | gray |
Country of origin | CH |
Габариты: глубина | 19.4 mm / 0.764 inch |
Drilled hole diameter (tolerance) | 1.5(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 4 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 2.5 mm² |
Fire load | 0.414 MJ |
GTIN | 4045454140472 |
Height | 23 mm / 0.906 inch |
Height from the surface | 19 mm / 0.748 inch |
Material group | I |
Number of Poles | 8 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 10 mm (0.394 inch) |
Rated current | 32 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 800 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.8 x 1.2 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 4 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 8 |
Total number of potentials | 8 |
Вес | 21.212 г |
Ширина | 76.5 mm / 3.012 inch |
Серия: 745 (100 из 266)
- 745-280 745-281 745-283 745-284 745-285 745-300 745-302 745-302/005-000 745-303 745-303/000-016/999-950 745-303/005-000 745-304 745-304/005-000 745-305 745-306 745-307 745-308 745-309 745-310 745-3100 745-3102 745-3103 745-3104 745-3105 745-3106 745-3107 745-3108 745-3109 745-3110 745-3111 745-3112 745-312 745-3138 745-3152 745-3153 745-3154 745-3155 745-3156 745-3157 745-3158 745-3159 745-3160 745-3161 745-3162 745-3202 745-3203 745-3204 745-3205 745-3206 745-3207 745-3208 745-3209 745-3210 745-3211 745-3212 745-3252 745-3253 745-3254 745-3255 745-3256 745-3257 745-3258 745-3259 745-3260 745-3261 745-3262 745-338 745-340 745-345 745-352 745-352/005-000 745-353 745-354 745-354/005-000 745-355 745-356 745-357 745-358 745-359 745-360 745-362 745-380 745-3801 745-3803 745-3803/999-950 745-3804 745-3807 745-3808 745-381 745-382 745-383 745-384 745-385 745-390 745-391 745-392 745-393 745-394 745-395 745-500
- PCB Interconnect
7453208, 745 3208
