Datasheet Wago 770-864/011-000/073-000 — Даташит
Розетка для печатных плат; угловые; 4-пол.; Код. B
Купить 770-864/011-000/073-000 на РадиоЛоцман.Цены — от 553 до 68 ₽ Bu 4-контактный ,. пайку, Угловая | |||
770-864/011-000/073-000 Wago Оф. дистрибьютор | 553 ₽ | ||
770-864/011-000/073-000 Wago | 68 ₽ |
Coding | B |
Цвет | light green |
Connector connection type | for PCBs |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 26 mm / 1.024 inch |
Design | angled |
Drilled hole diameter (tolerance) | 1.5(+ 0.1 ... - 0.1) мм |
Fire load | 0.157 MJ |
GTIN | 4050821555803 |
Height | 18.1 mm / 0.713 inch |
Height from the surface | 14.6 mm / 0.575 inch |
Locking lever | да |
Locking of plug-in connection | locking lever |
Marking | 1 ⏚ 2 3 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Number of Poles | 4 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | 1 ⏚ 2 3 |
Rated current | 25 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Retention force of a plug-in connection | when locked: > 80N |
Solder pin arrangement | 2 in-line solder pins/pole |
Solder pin dimensions | 1 x 0.8 mm |
Solder pin length | 3.5 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of potentials | 4 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 8.558 г |
Ширина | 37 mm / 1.457 inch |
Серия: 770 (100 из 608)
- 770-843/060-000 770-843/062-000 770-844 770-844/011-000 770-844/011-000/060-000 770-844/011-000/062-000 770-844/011-000/064-000 770-844/060-000 770-844/062-000 770-844/064-000 770-845 770-845/011-000 770-845/011-000/060-000 770-845/011-000/062-000 770-845/011-000/064-000 770-845/060-000 770-845/062-000 770-845/064-000 770-853 770-853/011-000 770-853/011-000/060-000 770-853/011-000/062-000 770-853/060-000 770-853/062-000 770-854 770-854/011-000 770-854/011-000/060-000 770-854/011-000/062-000 770-854/011-000/064-000 770-854/060-000 770-854/062-000 770-854/064-000 770-855 770-855/011-000 770-855/011-000/060-000 770-855/011-000/062-000 770-855/011-000/064-000 770-855/060-000 770-855/062-000 770-855/064-000 770-863 770-863/011-000 770-863/011-000/071-000 770-863/011-000/073-000 770-863/071-000 770-863/073-000 770-864 770-864/011-000 770-864/011-000/071-000 770-864/011-000/072-000 770-864/011-000/073-000 770-864/071-000 770-864/072-000 770-864/073-000 770-865 770-865/011-000 770-865/073-000 770-873 770-873/011-000 770-873/011-000/071-000 770-873/011-000/073-000 770-873/071-000 770-873/073-000 770-874 770-874/011-000 770-874/011-000/071-000 770-874/011-000/072-000 770-874/011-000/073-000 770-874/071-000 770-874/072-000 770-874/073-000 770-875 770-875/011-000 770-875/011-000/073-000 770-875/073-000 770-883 770-883/011-000 770-883/011-000/081-000 770-883/011-000/082-000 770-883/081-000 770-883/082-000 770-884 770-884/011-000 770-884/011-000/081-000 770-884/081-000 770-885 770-885/011-000 770-885/011-000/080-000 770-885/011-000/082-000 770-885/080-000 770-885/082-000 770-893 770-893/011-000 770-893/011-000/081-000 770-893/011-000/082-000 770-893/081-000 770-893/082-000 770-894 770-894/011-000 770-894/011-000/081-000
770864/011000/073000, 770 864/011 000/073 000
