Datasheet Wago 770-112/041-000 — Даташит
Штекер; с корпусом разгрузки натяжения; 2-пол.; Код. A
Купить 770-112/041-000 на РадиоЛоцман.Цены — от 41 до 616 ₽ Steckergehaeuse mit Zugentlastung. s (25 шт) | |||
770-112/041-000 Wago | 41 ₽ | ||
770-112/041-000 Wago | 392 ₽ | ||
770-112/041-000 Wago Оф. дистрибьютор | 616 ₽ | ||
770-112/041-000 Wago | по запросу |
Actuation type | Operating tool Push-in |
Coding | A |
Цвет | black |
Connectable sheathed cable diameter | 7 … 10.5 mm |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 71 mm / 2.795 inch |
Fine-stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² / 20 … 16 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² / 20 … 14 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 16 AWG |
Fire load | 0.318 MJ |
GTIN | 4050821117940 |
Height | 15.9 mm / 0.626 inch |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | L N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Nominal cross section | 4 mm² |
Note (strip length) | see also packaging or instructions |
Number of Poles | 2 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | L N |
Rated current | 25 A |
Rated voltage (III / 3) | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Solid conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Solid conductor, push-in termination | 1.5 … 4 mm² / 16 … 12 AWG |
Strain relief | Strain relief housing |
Stranded conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
Strip length | 35 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of connection points | 4 |
Total number of potentials | 2 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 12.922 г |
Ширина | 24.6 mm / 0.969 inch |
Серия: 770 (100 из 608)
- 770-100 770-101 770-102/041-000 770-103 770-104 770-105 770-1102 770-1105 770-1105/022-000 770-111 770-1112 770-1115 770-1115/022-000 770-112/041-000 770-113 770-113/147-000 770-114 770-115 770-1162 770-1165 770-1172 770-1175 770-121 770-122/041-000 770-123 770-124 770-1242/076-000 770-1243/076-000 770-125 770-1252/076-000 770-1253/076-000 770-1303 770-1305 770-131 770-1313 770-1315 770-132/041-000 770-1324 770-1325 770-133 770-1334 770-1335 770-134 770-1343 770-135 770-1353 770-1363 770-1373 770-1373/146-000 770-1373/147-000 770-1373/148-000 770-1373/149-000 770-140 770-1601 770-1602 770-1603 770-1606 770-1608 770-1609 770-1610 770-1612 770-1613 770-1615 770-1626 770-1627 770-1631 770-1632 770-1633 770-1634 770-1636 770-1641 770-1642 770-1643 770-1643/080-000 770-1651 770-1652 770-1653 770-1656 770-1658 770-1659 770-1660 770-1661 770-1662 770-1663 770-1665 770-1681 770-1682 770-1683 770-1684 770-1686 770-1701 770-1702 770-1703 770-1704 770-1705 770-1706 770-1712 770-1713 770-1714 770-1715
770112/041000, 770 112/041 000
