Datasheet Wago 770-233/002-000 — Даташит
Штекер; с прямым заземляющим контактом; 3-пол.; Код. A
Купить 770-233/002-000 на РадиоЛоцман.Цены — от 133 до 475 ₽ Вставка с прямым контактом проводника заземл 3-пол., белые | |||
770-233/002-000 Wago | 133 ₽ | ||
770-233/002-000 Wago | 301 ₽ | ||
770-233/002-000 Wago Оф. дистрибьютор | 475 ₽ |
Coding | A |
Цвет | white |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 37.5 mm / 1.476 inch |
Drilled hole diameter (tolerance) | 5(+ 0.05 ... - 0.05) мм |
Fine-stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² / 20 … 16 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² / 20 … 14 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 16 AWG |
Fire load | 0.207 MJ |
GTIN | 4045454829551 |
Ground function | with preceding GND contact |
Height | 12.9 mm / 0.508 inch |
Locking lever | да |
Locking of plug-in connection | locking lever |
Marking | L ⏚ N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Nominal cross section | 4 mm² |
Note (strip length) | see also packaging or instructions |
Number of Poles | 3 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | L ⏚ N |
Rated current | 25 A |
Rated voltage (III / 3) | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Solid conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Solid conductor, push-in termination | 1.5 … 4 mm² / 16 … 12 AWG |
Stranded conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
Strip length | 9 mm / 0.35 Inch |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of connection points | 6 |
Total number of potentials | 3 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 11.366 г |
Ширина | 30 mm / 1.181 inch |
Серия: 770 (100 из 608)
- 770-1735 770-1736 770-1741 770-1742 770-1743 770-1743/080-000 770-1744 770-1745 770-1746 770-1746/080-000 770-1751 770-1752 770-1753 770-1761 770-1762 770-1763 770-1781 770-1782 770-1783 770-1947 770-201 770-202 770-203 770-203/035-000 770-204 770-205 770-2105 770-2115 770-2115/007-000 770-212 770-213 770-213/002-000 770-213/035-000 770-214 770-215 770-221 770-222 770-223 770-223/035-050 770-224 770-225 770-2303 770-2305 770-2313 770-2313/007-000 770-2315 770-232 770-2324 770-2325 770-233 770-233/002-000 770-233/035-050 770-2334 770-2334/007-000 770-2335 770-2335/007-000 770-234 770-2343 770-235 770-2353 770-2363 770-242 770-242/060-000 770-243 770-243/060-000 770-243/062-000 770-243/081-000 770-244 770-244/060-000 770-244/062-000 770-244/064-000 770-244/081-000 770-245 770-245/060-000 770-245/062-000 770-245/064-000 770-252 770-252/060-000 770-253 770-253/060-000 770-253/062-000 770-253/081-000 770-254 770-254/060-000 770-254/062-000 770-254/064-000 770-254/081-000 770-255 770-255/060-000 770-255/062-000 770-255/064-000 770-262 770-263 770-263/071-000 770-263/073-000 770-264 770-264/071-000 770-264/072-000 770-264/073-000 770-265
770233/002000, 770 233/002 000
