Аналоги реле Phoenix Contact, Finder, Omron, ABB, Schneider
Datasheet Wago 770-255/060-000 — Даташит
Серия770
Модель770-255/060-000
Штекер; 5-пол.; Код. B
STIFTTEIL 5-POL. 2L GRAU KOD. B (50 шт)
Industrial Module
107 ₽
770-255/060-000
Оф. дистрибьютор
701 ₽
Actuation typeOperating tool Push-in
CodingB
Цветgray
Country of originDE
Degree of protectionIP20
Габариты: глубина37.5 mm / 1.476 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
Fire load0.324 MJ
GTIN4050821494188
Height12.9 mm / 0.508 inch
Locking leverнет
MarkingN ⏚ L1 L2 L3
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Number of Poles5
Pin spacing10 mm (0.394 inch)
Potential markingN ⏚ L1 L2 L3
Rated current25 A
Rated voltage (III / 3)400 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points10
Total number of potentials5
Вес16.566 г
Ширина50 mm / 1.969 inch
770255/060000, 770 255/060 000
На английском языке: Datasheet Wago 770-255/060-000
