Datasheet Wago 770-661 — Даташит
Распределительный соединитель; с корпусом разгрузки натяжения; 3- и 5-конт.; 100% защита от неправильного подсоединения; Диаметр кабеля 9 - 13 мм; с избирательностью по фазе
Купить 770-661 на РадиоЛоцман.Цены — от 245 до 8 000 ₽ Распределитель С фиксирующей скобой 3 и 5-конт. | |||
MS77066-1 | 245 ₽ | ||
770-661 Wago Оф. дистрибьютор | 3 207 ₽ | ||
770-661 Wago | 90 ₽ | ||
MS770661 | 8 000 ₽ |
Actuation type | Operating tool Push-in |
Coding | A |
Цвет | white |
Connectable sheathed cable diameter | 9 … 13 mm |
Contact material | Copper or copper alloy, surface-treated |
Contact type (pluggable connector) | Socket/plug |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 48 mm / 1.89 inch |
Fine-stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² / 20 … 16 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² / 20 … 14 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 16 AWG |
Fire load | 0.995 MJ |
GTIN | 4045454558451 |
Ground function | with preceding GND contact |
Height | 31.7 mm / 1.248 inch |
Locking lever | да |
Locking of plug-in connection | locking lever |
Marking | N ⏚ L1 L2 L3 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Nominal cross section | 4 mm² |
Number of Poles | 5 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | N ⏚ L1 L2 L3 |
Rated current | 25 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated impulse voltage (III / 3) 2 | 4 kV |
Rated voltage (III / 3) | 400 В |
Rated voltage (III / 3) 2 | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Solid conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Solid conductor, push-in termination | 1.5 … 4 mm² / 16 … 12 AWG |
Stranded conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
Strip length | 9 mm / 0.35 Inch |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of connection points | 5 |
Total number of potentials | 5 |
Type of distribution connector | Distribution connector with phase selection |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 45.856 г |
Ширина | 50 mm / 1.969 inch |
Серия: 770 (100 из 608)
- 770-513/023-000 770-513/032-000 770-513/035-000 770-513/038-000 770-514 770-514/023-000 770-515 770-515/021-000 770-515/023-000 770-516/029-000 770-517/047-000 770-523 770-601 770-603 770-605 770-606 770-607 770-608 770-609 770-611 770-615 770-617 770-618 770-619 770-620 770-621 770-622 770-6223 770-623 770-624 770-625 770-626 770-627 770-630 770-633 770-634 770-635 770-636 770-637 770-638 770-640 770-643 770-644 770-645 770-653 770-655 770-656 770-657 770-658 770-659 770-661 770-665 770-667 770-670 770-671 770-672 770-673 770-674 770-675 770-676 770-677 770-680 770-683 770-684 770-685 770-686 770-687 770-688 770-690 770-693 770-694 770-695 770-703 770-703/009-000 770-704 770-704/009-000 770-705 770-705/009-000 770-713 770-713/007-000 770-714 770-714/007-000 770-715 770-715/007-000 770-723 770-723/009-000 770-724 770-724/009-000 770-725 770-725/009-000 770-733 770-733/007-000 770-734 770-734/007-000 770-735 770-735/007-000 770-743 770-743/060-000 770-743/062-000 770-744
