Datasheet Wago 770-703 — Даташит
Защелкивающаяся розетка; 3-пол.; Код. A
Купить 770-703 на РадиоЛоцман.Цены — от 121 до 19 257 ₽ 14 предложений от 9 поставщиков Прямоугольный разъем питания, монтаж в панель, 3 контакт(-ов), Серия WINSTA MIDI 770 | |||
770-703/009-000 Wago | 121 ₽ | ||
770-703 Wago | 157 ₽ | ||
770-703/009-000 Wago Оф. дистрибьютор | 433 ₽ | ||
Вертикальный накопитель Durable - 770703 | 593 ₽ |
Actuation type | Operating tool Push-in |
Coding | A |
Цвет | black |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 36 mm / 1.417 inch |
Fine-stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² / 20 … 16 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² / 20 … 14 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 16 AWG |
Fire load | 0.236 MJ |
GTIN | 4044918252560 |
Gehäuseblechstärke | 0.5 … 2 mm / 0.02 … 0.079 inch |
Height | 17.5 mm / 0.689 inch |
Locking lever | да |
Locking of plug-in connection | locking lever |
Marking | L ⏚ N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Mounting type | Snap-in |
Nominal cross section | 4 mm² |
Note (strip length) | see also packaging or instructions |
Number of Poles | 3 |
Number of test slots | 3 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | L ⏚ N |
Product Group | 20 (WINSTA) |
Rated current | 25 A |
Rated voltage (III / 3) | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Solid conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Solid conductor, push-in termination | 1.5 … 4 mm² / 16 … 12 AWG |
Stranded conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
Strip length | 9 mm / 0.35 Inch |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of connection points | 6 |
Total number of potentials | 3 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 11.93 г |
Ширина | 35.5 mm / 1.398 inch |
Серия: 770 (100 из 608)
- 770-618 770-619 770-620 770-621 770-622 770-6223 770-623 770-624 770-625 770-626 770-627 770-630 770-633 770-634 770-635 770-636 770-637 770-638 770-640 770-643 770-644 770-645 770-653 770-655 770-656 770-657 770-658 770-659 770-661 770-665 770-667 770-670 770-671 770-672 770-673 770-674 770-675 770-676 770-677 770-680 770-683 770-684 770-685 770-686 770-687 770-688 770-690 770-693 770-694 770-695 770-703 770-703/009-000 770-704 770-704/009-000 770-705 770-705/009-000 770-713 770-713/007-000 770-714 770-714/007-000 770-715 770-715/007-000 770-723 770-723/009-000 770-724 770-724/009-000 770-725 770-725/009-000 770-733 770-733/007-000 770-734 770-734/007-000 770-735 770-735/007-000 770-743 770-743/060-000 770-743/062-000 770-744 770-744/060-000 770-744/062-000 770-744/064-000 770-745 770-745/060-000 770-745/062-000 770-745/064-000 770-753 770-753/060-000 770-753/062-000 770-754 770-754/060-000 770-754/062-000 770-754/064-000 770-755 770-755/060-000 770-755/062-000 770-755/064-000 770-763 770-763/071-000 770-763/073-000 770-764
