Datasheet Wago 770-1105/022-000 — Даташит
Серия770
Модель770-1105/022-000
Socket
Industrial Module
89 ₽
Wago 770-1105/022-000 Wago 770-1105/022-000
Actuation typeOperating tool Push-in
CodingI
Цветblue
Connectable sheathed cable diameter9 … 13 mm
Continuous operating temperature−35 … +85 °C
Degree of protectionIP20
Габариты: глубина75.9 mm / 2.988 inch
Fine-stranded conductor0.5 … 4 mm² / 20 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1.5 mm² / 20 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
GTIN4050821223016
Height17 mm / 0.669 inch
Locking leverнет
MarkingN ⏚ L DA- DA+
Mismating protectionYes
Nominal cross section4 mm²
Note (strip length)see also packaging or instructions
Note on Continuous Service TemperatureInsulating parts for temperatures ≤ 105°C
Note on Protection TypeOnly in mated condition with strain relief housing (These compact connectors are not designed for use in open, easily accessible areas)
Number of Poles5
Packaging typeBOX
Pin spacing10 mm (0.394 inch)
Potential markingN ⏚ L DA- DA+
Processing temperature-5 … +40 °C
Rated current25 A
Rated voltage (III / 3)400 В
Solid conductor0.5 … 4 mm² / 20 … 12 AWG
Solid conductor, push-in termination1.5 … 4 mm² / 16 … 12 AWG
Strain reliefZugentlastungsgehäuse
Stranded conductor0.5 … 2.5 mm² / 20 … 14 AWG
Strip length55 мм
Total number of connection points10
Total number of potentials5
Вес28.945 г
Ширина54.6 mm / 2.15 inch
7701105/022000, 770 1105/022 000
На английском языке: Datasheet Wago 770-1105/022-000
