Datasheet Wago 890-282/080-000 — Даташит
Разъем; 2-пол.; Код. B
Купить 890-282/080-000 на РадиоЛоцман.Цены — от 63 до 266 ₽ Socket (50 шт) | |||
890-282/080-000 Wago | 63 ₽ | ||
890-282/080-000 Wago | 266 ₽ | ||
890-282/080-000 Wago | по запросу |
Actuation type | Operating tool Push-in |
Coding | B |
Цвет | pink |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 34.1 mm / 1.343 inch |
Fine-stranded conductor | 0.25 … 1.5 mm² / 22 … 16 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² / 22 … 20 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 0.75 mm² / 22 … 20 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 20 AWG |
Fire load | 0.052 MJ |
GTIN | 4050821515470 |
Height | 11.7 mm / 0.461 inch |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | I+ I- |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Nominal cross section | 1.5 mm² |
Note (strip length) | see also packaging or instructions |
Number of Poles | 2 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | I+ I- |
Rated current | 16 A |
Rated voltage (III / 3) | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Solid conductor | 0.25 … 1.5 mm² / 22 … 16 AWG |
Solid conductor, push-in termination | 0.75 … 1.5 mm² / 20 … 16 AWG |
Stranded conductor | 0.25 … 1 mm² / 22 … 18 AWG |
Strip length | 9 mm / 0.35 Inch |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of connection points | 2 |
Total number of potentials | 2 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 2.596 г |
Ширина | 10.4 mm / 0.409 inch |
Серия: 890 (100 из 384)
- 890-225 890-232 890-233 890-234 890-235 890-242 890-242/060-000 890-243 890-243/060-000 890-243/062-000 890-244 890-244/060-000 890-244/062-000 890-244/064-000 890-245 890-245/060-000 890-245/062-000 890-252 890-252/060-000 890-253 890-253/060-000 890-253/062-000 890-254 890-254/060-000 890-254/062-000 890-254/064-000 890-255 890-255/060-000 890-255/062-000 890-262 890-263 890-263/071-000 890-263/073-000 890-264 890-264/071-000 890-264/072-000 890-264/073-000 890-265 890-265/073-000 890-272 890-273 890-273/071-000 890-273/073-000 890-274 890-274/071-000 890-274/072-000 890-274/073-000 890-275 890-275/073-000 890-282 890-282/080-000 890-282/082-000 890-283 890-283/081-000 890-283/082-000 890-284 890-284/081-000 890-285 890-285/080-000 890-285/082-000 890-292 890-292/080-000 890-292/082-000 890-293 890-293/081-000 890-293/082-000 890-294 890-294/081-000 890-295 890-295/080-000 890-295/082-000 890-302 890-303 890-304 890-305 890-310 890-3102 890-3102/011-000 890-3105 890-3105/011-000 890-311 890-3112 890-3112/011-000 890-3115 890-3115/011-000 890-382 890-383 890-384 890-385 890-392 890-393 890-502 890-502/342-000 890-503 890-504 890-505 890-512 890-512/342-000 890-513 890-514
890282/080000, 890 282/080 000
