Datasheet Wago 890-295/082-000 — Даташит
Серия890
Модель890-295/082-000
Штекер; 5-пол.; Код. B
Plug without strain relief housing 5-pole, pink (50 шт)
Industrial Module
107 ₽
Akcel
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
Actuation typeOperating tool Push-in
CodingB
Цветpink
Country of originPL
Degree of protectionIP20
Габариты: глубина34.1 mm / 1.343 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
GTIN4055143500098
Height11.7 mm / 0.461 inch
Locking leverнет
MarkingN ⏚ L - +
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Note on rated current13 A for 3-pole load10 A for 4- and 5-pole load
Number of Poles5
Potential markingN ⏚ L - +
Rated current16 A
Rated voltage (III / 3)400 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length9 mm / 0.35 Inch
Total number of connection points5
Total number of potentials5
Вес5.474 г
Ширина23.6 mm / 0.929 inch
890295/082000, 890 295/082 000
На английском языке: Datasheet Wago 890-295/082-000
