Datasheet ON Semiconductor NCV20074DTBR2G — Даташит
Производитель | ON Semiconductor |
Серия | NCS20074 |
Модель | NCV20074DTBR2G |
Operational Amplifier, Wide supply range, 3Mhz CMOS Op-Amp
Купить NCV20074DTBR2G на РадиоЛоцман.Цены — от 40 до 146 ₽ 31 предложений от 13 поставщиков OP Amp Quad GP R-R O/P 36V Automotive 14Pin TSSOP T/R | |||
NCV20074DTBR2G ON Semiconductor | 40 ₽ | ||
NCV20074DTBR2G ON Semiconductor | от 43 ₽ | ||
NCV20074DTBR2G ON Semiconductor | от 93 ₽ | ||
NCV20074DTBR2G ON Semiconductor | по запросу |
The NCS2007x series operational amplifiers provide rail−to−rail output operation, 3 MHz bandwidth, and are available in single, dual, and quad configurations.
Rail−to−rail operation enables the user to make optimal use of the entire supply voltage range. The NCS2007x can operate on supply voltages as low as 2.7 V up to 36V over the temperature range of −40°C to 125°C. At a 2.7 V supply, the high bandwidth provides a slew rate of 2.8 V/µs while only consuming 405 µA of quiescent current per channel. The wide supply range allows the NCS2007x to run on supply voltages as high as 36 V, making it ideal for a broad range of applications. Since this is a CMOS device, high input impedance and low bias currents make it ideal for interfacing to a wide variety of signal sensors. The NCS2007x devices are available in a variety of compact packages.
Корпус | TSSOP-14 |
Код корпуса | 948G-01 |
Стандарты и нормы | AEC Qualified | PPAP Capable | Pb-free | Halide free |
- NCS20074DR2G NCS20074DTBR2G NCV20074DR2G NCV20074DTBR2G
- Analog, Logic, & Timing > Amplifiers & Comparators > Operational Amplifiers (Op Amps)
