Datasheet ON Semiconductor NCS20074 — Даташит
Производитель | ON Semiconductor |
Серия | NCS20074 |
Operational Amplifier, Wide supply range, 3Mhz CMOS Op-Amp
Купить NCS20074 на РадиоЛоцман.Цены — от 87 до 8 015 ₽ | |||
NCS20074DG ON Semiconductor | 87 ₽ | ||
NCS20074DG | 8 015 ₽ | ||
NCS20074 ON Semiconductor | по запросу |
The NCS2007x series operational amplifiers provide rail−to−rail output operation, 3 MHz bandwidth, and are available in single, dual, and quad configurations.
Rail−to−rail operation enables the user to make optimal use of the entire supply voltage range. The NCS2007x can operate on supply voltages as low as 2.7 V up to 36V over the temperature range of −40°C to 125°C. At a 2.7 V supply, the high bandwidth provides a slew rate of 2.8 V/µs while only consuming 405 µA of quiescent current per channel. The wide supply range allows the NCS2007x to run on supply voltages as high as 36 V, making it ideal for a broad range of applications. Since this is a CMOS device, high input impedance and low bias currents make it ideal for interfacing to a wide variety of signal sensors. The NCS2007x devices are available in a variety of compact packages.
NCS20074DR2G | NCS20074DTBR2G | NCV20074DR2G | NCV20074DTBR2G | |
Статус продукта | В производстве (Рекомендуется для новых разработок) | В производстве (Рекомендуется для новых разработок) | В производстве (Рекомендуется для новых разработок) | В производстве (Рекомендуется для новых разработок) |
N | 1 | 2 | 3 | 4 |
Корпус | SOIC-14 | TSSOP-14 | SOIC-14 | TSSOP-14 |
Код корпуса | 751A-03 | 948G-01 | 751A-03 | 948G-01 |
Стандарты и нормы | Pb-free | Halide free | Pb-free | Halide free | AEC Qualified | PPAP Capable | Pb-free | Halide free | AEC Qualified | PPAP Capable | Pb-free | Halide free |
- Analog, Logic, & Timing > Amplifiers & Comparators > Operational Amplifiers (Op Amps)
