Datasheet Microchip MCP6034-E/STVAO — Даташит
Производитель | Microchip |
Серия | MCP6034 |
Модель | MCP6034-E/STVAO |
The MCP6034 operational amplifier (op amp) has a gain bandwidth of 10 kHz with a low typical operating current of 900 nA and an offset voltage that is less than 150 uV.
Datasheet MCP6031, MCP6032, MCP6035, MCP6034
PDF, 652 Кб, Язык: анг., Файл опубликован: 10 фев 2010, Страниц: 34
The MCP6031 operational amplifier (op amp) has a gain bandwidth of 10 kHz with a low typical operating current of 900 nA and an offset voltage that is less than 150 uV
Datasheet MCP601, MCP601R, MCP602, MCP603, MCP604
PDF, 600 Кб, Язык: анг., Файл опубликован: 17 дек 2007, Страниц: 34
MCP601 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 uA and an offset voltage that is less than 2 mV
Купить MCP6034-E на РадиоЛоцман.Цены — от 92 до 448 ₽ 33 предложений от 23 поставщиков MICROCHIP MCP6034-E/SL Operational Amplifier, Quad, 4 Amplifier, 10kHz, 0.004V/µs, 1.8V to 5.5V, SOIC, 14Pins | |||
MCP6034-E/ST Microchip | 92 ₽ | ||
MCP6034-E/ST Microchip | 96 ₽ | ||
MCP6034-E/SL Microchip | 144 ₽ | ||
MCP6034-E/SL Microchip | по запросу |
The MCP6034 uses Microchip's advanced CMOS technology, which provides low bias current, high-speed operation, high open-loop gain and rail-to-rail input and output swing. The MCP6034 operates with a single supply voltage that can be as low as 1.8V, while drawing less than 1 uA of quiescent current. The MCP6034 is available in standard 14-lead SOIC and TSSOP packages. AEC-Q100 Grade 1 qualification is available for this device
Корпус | TSSOP |
Количество каналов | 4 |
Aol | 115 дБ |
Automotive Recommended | Yes |
CMRR Min | 70 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 10 kHz |
Ib | 1 pA |
Input Voltage Noise Density | 165 nV/rt(Hz) |
Iq Max | 1.35 µA |
Iq Typical | 0.9 µA |
Isc | 23 мА |
Lead Count | 14 |
Operating Voltage Range | 1.8 - 5.5 В |
PM | 65 deg |
PSRR Min | 70 дБ |
Package Width | 4.4mm |
Rail-To-Rail | In/Out |
Скорость нарастания | 0.004 V/µS |
Unity Gain Stable | Yes |
Vos Max | 150 µV |
ΔVos/ΔTa | 3 µV/°C |
Серия: MCP6034 (6)
- MCP6034-E/SL MCP6034-E/ST MCP6034-E/STVAO MCP6034T-E/SL MCP6034T-E/ST MCP6034T-E/STVAO
- Amplifiers and Linear > Operational Amplifiers > Precision
MCP6034E/STVAO, MCP6034 E/STVAO
