Datasheet Microchip MCP624T-E/STVAO — Даташит
Производитель | Microchip |
Серия | MCP624 |
Модель | MCP624T-E/STVAO |
The MCP62x family of operational amplifiers feature low offset.
Datasheet MCP621S, MCP621S, MCP622, MCP623, MCP624, MCP625, MCP629
PDF, 2.2 Мб, Язык: анг., Файл опубликован: 7 авг 2014, Страниц: 62
Купить MCP624T-E на РадиоЛоцман.Цены — от 140 до 207 ₽ 10 предложений от 10 поставщиков QUAD OP-AMP, 200uV OFFSET-MAX, 20MHz BAND WIDTH, PDSO14, 4.4MM, PLASTIC, TSSOP-14 | |||
MCP624T-E/SL Microchip | 140 ₽ | ||
MCP624T-E/ST Microchip | 194 ₽ | ||
MCP624T-E/ST Microchip | по запросу | ||
At power-up, these op amps are self-calibrated using mCal. Some package options also provide a calibration/chip select pin that supports a low power mode of operation, with offset calibration at the time normal operation is re-started. These amplifiers are optimized for high speed, low noise and distortion, single-supply operation with rail-to-rail output and an input that includes the negative rail. AEC-Q100 Grade 1 qualification is available for this device
Корпус | TSSOP |
Количество каналов | 4 |
Aol | 117 дБ |
Automotive Recommended | Yes |
CMRR Min | 65 дБ |
Description | Linear Op Amps |
EMI Protection | No |
GBWP | 20000 kHz |
Ib | 5 pA |
Input Voltage Noise Density | 13 nV/rt(Hz) |
Iq Max | 3600 µA |
Iq Typical | 2500 µA |
Isc | 70 мА |
Lead Count | 14 |
Operating Voltage Range | 2.5 - 5.5 В |
PM | 60 deg |
PSRR Min | 61 дБ |
Package Width | 4.4mm |
Rail-To-Rail | Out |
Скорость нарастания | 10 V/µS |
Unity Gain Stable | Yes |
Vos Max | 200 µV |
ΔVos/ΔTa | 2 µV/°C |
MCP621 MCP621S MCP622 MCP623 MCP625 MCP629
Серия: MCP624 (30)
- MCP624-E/SL MCP624-E/ST MCP6241-E/MC MCP6241-E/MS MCP6241-E/P MCP6241-E/SN MCP6241RT-E/OT MCP6241T-E/MC MCP6241T-E/MS MCP6241T-E/OT MCP6241T-E/OTVAO MCP6241T-E/SN MCP6241UT-E/LT MCP6241UT-E/OT MCP6241UT-E/OTVAO MCP6242-E/MS MCP6242-E/P MCP6242-E/SN MCP6242T-E/MS MCP6242T-E/MSVAO MCP6242T-E/SN MCP6244-E/P MCP6244-E/SL MCP6244-E/ST MCP6244T-E/SL MCP6244T-E/ST MCP6244T-E/STVAO MCP624T-E/SL MCP624T-E/ST MCP624T-E/STVAO
- Amplifiers and Linear > Operational Amplifiers > Precision
MCP624TE/STVAO, MCP624T E/STVAO
