Datasheet Maxim MAXM86161EFD+T — Даташит
Производитель | Maxim |
Серия | MAXM86161 |
Модель | MAXM86161EFD+T |
Single-Supply Integrated Optical Module for HR and SpO2 Measurement
MAXM86161EFD+T Maxim | 1 004 ₽ | ||
MAXM86161EFD+T Maxim | по запросу | ||
MAXM86161EFD+T Analog Devices | по запросу |
The MAXM86161 is an ultra-low-power, completely integrated, optical data-acquisition system.
On the transmitter side, the MAXM86161 has three programmable high-current LED drivers. On the receiver side, MAXM86161 consists of a high efficiency PIN photo-diode and an optical readout channel. The optical readout has a low-noise signal conditioning analog front-end (AFE), including 19-bit ADC, an industry-lead ambient light cancellation (ALC) circuit, and a picket fence detect and replace algorithm. Due to the low power consumption, compact size, easy, flexible-to-use, and industry lead ambient light rejection capability of the MAXM86161, the device is ideal for a wide variety of optical sensing applications such as heart rate detection and pulse oximetry.
The MAXM86161 operates on a 3.0V to 5.5V VLED single supply voltage. It supports a standard compatible interface and fully autonomous operation. Each device has a large 128-word built-in FIFO. The MAXM86161 is available in compact 2.9mm x 4.3mm x 1.4mm, 14-pin OLGA package.
- MAXM86161EFD+ MAXM86161EFD+T
- Sensors
