Datasheet Maxim MAX16956AUBD/V+T — Даташит
Производитель | Maxim |
Серия | MAX16956 |
Модель | MAX16956AUBD/V+T |
36V, 300mA, Mini Buck Converter with 1.1µA IQ
Купить MAX16956AUBD/V+T на РадиоЛоцман.Цены — от 314 до 318 ₽ Buck Switching Regulator IC Positive Fixed 5V 1 Output 300mA 10-TFSOP, 10-MSOP (0.118, 3.00mm Width) Exposed Pad | |||
MAX16956AUBD/V+T Maxim | 314 ₽ | ||
MAX16956AUBD/V+T Maxim | 318 ₽ | ||
MAX16956AUBD/V+T Analog Devices | по запросу | ||
The MAX16956 is a small, synchronous buck converter with integrated high-side and low-side switches.
The device is designed to deliver up to 300mA with input voltages from 3.5V to 36V, while using only 1.1µA quiescent current at no load (fixed-output versions). Voltage quality can be monitored by observing the active-low RESET signal. The device can operate near dropout by running at 97% duty cycle, making it ideal for automotive applications under cold-crank.
The device offers fixed-output voltages of 5V and 3.3V, as well as an adjustable version. The adjustable version allows the user to program the output voltage between 1V and 10V by using a resistor-divider. Frequency is fixed at 2.1MHz, which allows for small external components, reduced output ripple, and minimized AM radio interference. The device offers both forced-PWM and skip modes of operation, with ultra-low quiescent current of 1.1µA in skip mode. The device can be ordered with spread-spectrum frequency modulation designed to minimize EMI-radiated emissions due to the switching frequency.
The MAX16956 is available in a small (3mm × 3mm) 10-pin µMAX package and operates across the full automotive temperature range of -40°C to +125°C. The device is AEC-Q100 qualified.
- Power > Switching Regulators
