Datasheet Microchip PIC18F56Q43 — Даташит
Производитель | Microchip |
Серия | PIC18F56Q43 |
Модель | PIC18F56Q43 |
PIC18 Q43 combines our most popular, versatile and easy to use Core Independent Peripherals with advanced interconnection capabilities that make sophisticated hardware customization effortless.
Product Brief PIC18 Q43
PDF, 273 Кб, Язык: анг., Файл закачен: 13 ноя 2019, Страниц: 20
Купить PIC18F56Q43 на РадиоЛоцман.Цены — от 150 до 446 ₽ 14 предложений от 7 поставщиков 8-bit Microcontrollers - MCU 64KB Flash, 4KB RAM, 3x 16-bit PWMs, 6 ch DMA Comparator, 8-bit DAC, 12-bit ADCCView in Development... | |||
PIC18F56Q43-I/6LX Microchip | 150 ₽ | ||
PIC18F56Q43-I/6LX Microchip | 158 ₽ | ||
PIC18F56Q43-E/6LX | от 161 ₽ | ||
PIC18F56Q43-I/6LX | по запросу |
These 28-, 40- and 48-pin devices are equipped with a 12-bit ADC with computation, six 16-bit dual PWMs outputs, six Direct Memory Access channels, eight Configurable Logic Cells (CLCs) and five UARTS. This combination simplifies the creation of customized hardware-based functions to improve system response and reduce code development time for a variety of real-time control applications.
ADC Input | 43 |
ADC with Computation | Yes |
Angular Timer | No |
Архитектура | 8 |
CPU Type | 8-bit PIC MCU |
CRC | Yes |
Class B Support | No |
Complementary Waveform Generator / Complementary Output Generator | 3 |
Configurable Logic Cell | 8 CLC/CCL |
Data Signal Modulator | 1 |
Emulated EEPROM in Flash | 1024 |
Hardware Limit Timer | 3 |
Hardware Touch Peripheral | ADC2 with HCVD |
High Voltage Capable | No |
I2C | 1 |
Internal Oscillator | 64MHZ, |
Math Accelerator | No |
Max 16-Bit Digital Timers | 4 |
Max 8-Bit Digital Timers | 3 |
Max ADC Resolution | 12 Bits |
Max CPU Speed | 64 МГц |
Max DAC Resolution | 8 Bits |
Max PWM outputs | 6 including complementary |
Количество компараторов | 2 |
Number of DACs | 1 |
Numerically Controlled Oscillator | 3 |
PWM Max Resolution | 16 Bits |
Pin count | 48 |
Размер памяти программ | 64 KB |
SPI | 2 |
SRAM | 4096 Bytes |
Signal Measurement Timer | 1 |
Temp Range Max | 125 |
Temp Range Min | -40 |
UART | 5 |
Zero Cross detect | Yes |
PIC18F25Q43 PIC18F26Q43 PIC18F27Q43 PIC18F45Q43 PIC18F46Q43 PIC18F47Q43 PIC18F55Q43 PIC18F57Q43
Серия: PIC18F56Q43 (7)
- 8-bit Microcontrollers > PIC18 MCU
