Datasheet Maxim MAX518AEPA+ — Даташит
Производитель | Maxim |
Серия | MAX518 |
Модель | MAX518AEPA+ |
2-Wire, Serial, 8-Bit DACs with Rail-to-Rail Outputs
Купить MAX518AEPA+ на РадиоЛоцман.Цены — от 565 до 18 838 ₽ 19 предложений от 12 поставщиков D/A Converter, 2 Func, Serial Input Loading, 6us Settling Time, PDIP8, 0.3INCH, PLASTIC, DIP-8 | |||
MAX518AEPA+ Maxim | 565 ₽ | ||
MAX518AEPA+ Maxim | 661 ₽ | ||
MAX518AEPA+ Maxim | 695 ₽ | ||
MAX518AEPA+ Maxim | по запросу |
Dual, Serial, Voltage-Output DAC in a SO Package
The MAX517/MAX518/MAX519 are 8-bit voltage output digital-to-analog converters (DACs) with a simple 2-wire serial interface that allows communication between multiple devices.
They operate from a single 5V supply and their internal precision buffers allow the DAC outputs to swing rail-to-rail.
The MAX517 is a single DAC and the MAX518/MAX519 are dual DACs. The MAX518 uses the supply voltage as the reference for both DACs. The MAX517 has a reference input for its single DAC and each of the MAX519's two DACs has its own reference input.
The MAX517/MAX518/MAX519 feature a serial interface and internal software protocol, allowing communication at data rates up to 400kbps. The interface, combined with the double-buffered input configuration, allows the DAC registers of the dual devices to be updated individually or simultaneously. In addition, the devices can be put into a low-power shutdown mode that reduces supply current to 4µA. Power-on reset ensures the DAC outputs are at 0V when power is initially applied.
The MAX517/MAX518 are available in space-saving 8-pin DIP and SO packages. The MAX519 comes in 16-pin DIP and SO packages.
- Analog > Data Converters > Digital-to-Analog Converters
