Datasheet Maxim MAX518AESA+T — Даташит
Производитель | Maxim |
Серия | MAX518 |
Модель | MAX518AESA+T |
2-Wire, Serial, 8-Bit DACs with Rail-to-Rail Outputs
Купить MAX518AESA+T на РадиоЛоцман.Цены — от 365 до 648 ₽ 8 предложений от 8 поставщиков Цифро-аналоговые преобразователи (ЦАП) | |||
MAX518AESA+T Maxim | 365 ₽ | ||
MAX518AESA+T Maxim | 639 ₽ | ||
MAX518AESA-T Maxim | по запросу | ||
MAX518AESA+T Analog Devices | по запросу |
Dual, Serial, Voltage-Output DAC in a SO Package
The MAX517/MAX518/MAX519 are 8-bit voltage output digital-to-analog converters (DACs) with a simple 2-wire serial interface that allows communication between multiple devices.
They operate from a single 5V supply and their internal precision buffers allow the DAC outputs to swing rail-to-rail.
The MAX517 is a single DAC and the MAX518/MAX519 are dual DACs. The MAX518 uses the supply voltage as the reference for both DACs. The MAX517 has a reference input for its single DAC and each of the MAX519's two DACs has its own reference input.
The MAX517/MAX518/MAX519 feature a serial interface and internal software protocol, allowing communication at data rates up to 400kbps. The interface, combined with the double-buffered input configuration, allows the DAC registers of the dual devices to be updated individually or simultaneously. In addition, the devices can be put into a low-power shutdown mode that reduces supply current to 4µA. Power-on reset ensures the DAC outputs are at 0V when power is initially applied.
The MAX517/MAX518 are available in space-saving 8-pin DIP and SO packages. The MAX519 comes in 16-pin DIP and SO packages.
- Analog > Data Converters > Digital-to-Analog Converters
