Datasheet Diodes BCR430UW6 — Даташит
Производитель | Diodes |
Серия | BCR430UW6 |
Low Dropout Voltage Linear LED Driver Ic In SOT26
Datasheet BCR430UW6
PDF, 682 Кб, Язык: анг., Файл закачен: 10 янв 2020, Страниц: 9
Купить BCR430UW6 на РадиоЛоцман.Цены — от 11 до 2 588 ₽ 21 предложений от 10 поставщиков IC: driver; single transistor; current regulator,LED driver | |||
BCR430UW6-7 Diodes | 11 ₽ | ||
BCR430UW6Q-7 Diodes | 27 ₽ | ||
BCR430UW6-7 Diodes | по запросу |
The BCR430U is a monolithically integrated linear LED controller designed to function as a Constant Current Regulator (CCR) for linear LED driving.
The device operates over a voltage range from 5V to 42V and regulates the output LED current up to 100mA, set by an external resistor. It is designed for driving LEDs in strings and will reduce current at increasing temperatures to self-protect. The low voltage drop during current regulation allows efficient driving of LED strings with a range of forward voltages and supply voltage tolerances.
BCR430UW6-7 | |
N | 1 |
Корпус | SOT26 (SC74R) |
Parameters / Models | BCR430UW6-7 |
Точность | 5 % |
Automotive Compliant PPAP | No |
Dimming | PWM |
LED Current | 5mA to 100mA mA |
LED Current Sense Voltage | 892 mV |
Maximum Supply Voltage | 42 V |
Maximum VOUT | 40 V |
Minimum Supply Voltage | 5 V |
Количество каналов | 1 |
Выходной ток | 100 mA |
Qualified to AECQ10x | No |
Temperature Range | -55 to 150 °C |
Topology | Linear LED Driver |
Серия: BCR430UW6 (1)
- Power Management > LED Drivers > Linear LED Drivers
