Datasheet Broadcom HCPL-181-06BE — Даташит
DC-Input Lead Free General Purpose Phototransistor Optocoupler
Datasheet HCPL-181
PDF, 828 Кб, Язык: анг., Файл закачен: 18 янв 2020, Страниц: 8
Phototransistor Optocoupler SMD Mini-Flat Type
23 предложений от 13 поставщиков Оптопара, с транзистором на выходе, 1 канал, SOIC, 4 вывод(-ов), 50 мА, 3.75 кВ, 130 % | |||
HCPL-181-06BE-ML | 11 ₽ | ||
HCPL-181-06BE Broadcom | 36 ₽ | ||
HCPL-181-06BE Broadcom | от 49 ₽ | ||
HCPL-181-06BE Broadcom | по запросу |
The HCPL-181-000E optocoupler contains a light emitting diode optically coupled to a phototransistor.
It is packaged in a 4-pin mini-flat SMD package with a 2.0 mm profile. The small dimension of this product allows significant space saving. The package volume is 30% smaller than that of conventional DIP type. Input-output isolation voltage is 3750 Vrms. Response time, tr, is typically 4 ms and minimum CTR is 50% at input current of 5 mA.
Features
- Current Transfer Ratio (CTR: min. 50% at IF = 5 mA, VCE = 5 V)
- High input-output isolation voltage (Viso = 3750 Vrms)
- High collector-emitter voltage (VCEO = 80 V)
- Response time (tr: typ., 4 us at VCE = 2 V, IC = 2 mA, RL = 100 Ohms)
- Mini-flat package (2.0 mm profile) in tape and reel package
- UL approved
- CSA approved
- IEC/EN/DIN EN 60747-5-2 approved
- Options available are:
- 060E = IEC/EN/DIN EN 60747-5-2 Option
- 00AE = Rank Mark A
- 00BE = Rank Mark B
- 00CE = Rank Mark C
- 00DE = Rank Mark D
Серия: HCPL-181 (10)
- Optocouplers and Opto-Isolators > Industrial Plastic > Other Products > Phototransistors
HCPL18106BE, HCPL 181 06BE
