Datasheet Signal Transformer 241-3-120 — Даташит
Производитель | Signal Transformer |
Серия | 241 |
Модель | 241-3-120 |
Signal's 241 transformers use a split bobbin construction that provides superior isolation and low capacitive coupling
Datasheet 241
PDF, 1.0 Мб, Язык: анг., Файл закачен: 30 янв 2020, Страниц: 3
Two-4-One Power Transformers. Split Bobbin Construction Providing Superior Isolation
Купить 241-3-120 на РадиоЛоцман.Цены — от 406 до 1 519 ₽ 6 предложений от 6 поставщиков XFRMR LAMINATED 2.4VA CHAS MOUNT | |||
241-3-120A10 Pulse Electronics | 406 ₽ | ||
241-3-120A10 Pulse Electronics | 432 ₽ | ||
241-3-120 Signal Transformer | 1 519 ₽ | ||
241-3-120L Signal Transformer | по запросу |
Specifications
- Power - 2.4VA to 100VA
- Dielectric Strength - 2500 Vrms Hipot
- Primaries - Single or dual primaries (115V or 115/230V - 50/60Hz)
Features
- Secondary - Single center tapped secondary
- Terminals - Solder lug/quick connect type terminals
- Insulation - Class B (130ºC) UL 1446 E66312
Серия: 241 (100 из 110)
- 241-3-10 241-3-12 241-3-120 241-3-16 241-3-20 241-3-24 241-3-28 241-3-36 241-3-48 241-3-56 241-4-10 241-4-12 241-4-120 241-4-16 241-4-20 241-4-24 241-4-28 241-4-36 241-4-48 241-4-56 241-5-10 241-5-12 241-5-120 241-5-16 241-5-20 241-5-24 241-5-28 241-5-36 241-5-48 241-5-56 241-6-10 241-6-12 241-6-120 241-6-16 241-6-20 241-6-24 241-6-28 241-6-36 241-6-48 241-6-56 241-7-10 241-7-12 241-7-120 241-7-16 241-7-20 241-7-24 241-7-28 241-7-36 241-7-48 241-7-56 241-8-10 241-8-12 241-8-120 241-8-16 241-8-20 241-8-24 241-8-28 241-8-36 241-8-48 241-8-56 DP-241-4-10 DP-241-4-12 DP-241-4-120 DP-241-4-16 DP-241-4-20 DP-241-4-24 DP-241-4-28 DP-241-4-36 DP-241-4-48 DP-241-4-56 DP-241-5-10 DP-241-5-12 DP-241-5-120 DP-241-5-16 DP-241-5-20 DP-241-5-24 DP-241-5-28 DP-241-5-36 DP-241-5-48 DP-241-5-56 DP-241-6-10 DP-241-6-12 DP-241-6-120 DP-241-6-16 DP-241-6-20 DP-241-6-24 DP-241-6-28 DP-241-6-36 DP-241-6-48 DP-241-6-56 DP-241-7-10 DP-241-7-12 DP-241-7-120 DP-241-7-16 DP-241-7-20 DP-241-7-24 DP-241-7-28 DP-241-7-36 DP-241-7-4 DP-241-7-56
- Linear Magnetics > Isolation Transformer
2413120, 241 3 120
