Datasheet Diodes PI6CG33201C — Даташит
ПроизводительDiodes
СерияPI6CG33201C
МодельPI6CG33201C
Very Low Power 2-OUTPUT Pcie Clock Generator With On-Chip Termination
Datasheet PI6CG33201C
PDF, 1.7 Мб, Язык: анг., Файл закачен: 10 мар 2020, Страниц: 24
3.3V Very Low Power 2-Output PCIe Clock Generator With On-chip Termination
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
The PI6CG33201C is a 2-output very low power PCIe Gen1/Gen2/ Gen3/Gen4/Gen5 clock generator.
It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low power differential HCSL outputs with on-chip terminations. The on-chip termination can save 8 external resistors and make layout easier. An additional buffered reference output is provided to serve as a low noise reference for other circuitry.
It uses Diodes' proprietary PLL design to achieve very low jitter that meets PCIe Gen1/Gen2/Gen3/Gen4/Gen5 requirements.
It also provides various options such as different slew rate and amplitude through SMBUS so that users can configure the
device easily to get the optimized performance for their individual boards. The device also supports selectable spread-spectrum options to reduce EMI for various applications.
КорпусTQFN (ZD24) MSL1 Sn
FunctionGenerator
Input Type(s)HCSL
Jitter0.05
Количество выходов2
Output Frequency100
Output Type(s)HCSL
Skew50
Напряжение питания3.3
Temperature-40 to 85
  • Connectivity & Timing > Clock ICs > Application Specific Clocks > PCI Express (PCIe) Clock Generators
На английском языке: Datasheet Diodes PI6CG33201C
