Datasheet Diodes PI6CG33801C — Даташит
Производитель | Diodes |
Серия | PI6CG33801C |
Модель | PI6CG33801C |
Pci Express (pcie) Clock Generators
3.3V Very Low Power 8-Output PCIe Clock Generator With On-chip Termination
The PI6CG33801C is an 8-output very low power PCIe Gen1/Gen2/ Gen3/ Gen4/ Gen 5 clock generator.
It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low power differential HCSL outputs with on-chip terminations. The on-chip termination can save 32 external resistors and make layout easier. An additional buffered reference output is provided to serve as a low noise reference for other circuitry.
It uses Diodes' proprietary PLL design to achieve very low jitter that meets PCIe Gen1/Gen2/Gen3/Gen4/Gen 5 requirements.
It also provides various options such as different slew rate and amplitude through SMBUS so that users can configure the
device easily to get the optimized performance for their individual boards. The device also supports selectable spread-spectrum options to reduce EMI for various applications.
Корпус | TQFN (ZL48) MSL1 |
Function | Generator |
Input Type(s) | HCSL |
Jitter | 0.05 |
Количество выходов | 8 |
Output Frequency | 100 |
Output Type(s) | HCSL |
Skew | 50 |
Напряжение питания | 3.3 |
Temperature | -40 to 85 |
- Connectivity & Timing > Clock ICs > Application Specific Clocks > PCI Express (PCIe) Clock Generators
