Datasheet Diodes PI6CG33401 — Даташит
Производитель | Diodes |
Серия | PI6CG33401 |
Very Low Power 4-OUTPUT Pcie Clock Generator With On-Chip Termination
3.3V Very-Low-Power 4-Output PCIe Clock Generator With On-Chip Termination
Купить PI6CG33401 на РадиоЛоцман.Цены — от 195 до 30 178 ₽ 11 предложений от 7 поставщиков Микросхема: CLOCK GENERATOR W-QFN5050-32 T&R | |||
PI6CG33401CZHIEX Diodes | 195 ₽ | ||
PI6CG33401CZHIEX Diodes | 199 ₽ | ||
PI6CG33401ZHIEX Diodes | от 709 ₽ | ||
PI6CG33401CZHIEX | 30 178 ₽ |
The PI6CG33401 is a 4-output very-low-power PCIe Gen1/Gen2/ Gen3/Gen4/Gen 5 clock generator.
It uses 25MHz crystal or CMOS reference as an input to generate the 100MHz low-power differential HCSL outputs with on-chip terminations. The on-chip termination can save 16 external resistors and make layout easier. An additional buffered reference output is provided to serve as a low-noise reference for other circuitry.
It uses Diodes' proprietary PLL design to achieve very-low jitter that meets PCIe Gen1/Gen2/Gen3/Gen4/Gen5 requirements.
It also provides various options such as different slew rate and amplitude through SMBUS, so users can configure the device
easily to get the optimized performance for their individual boards. The device also supports selectable spread-spectrum options to reduce EMI for various applications.
PI6CG33401CZHIEX | PI6CG33401ZHIEX | PI6CG33401ZHIEX-13R | |
N | 1 | 2 | 3 |
Корпус | TQFN (ZH32) MSL1 PPF | TQFN (ZH32) MSL1 PPF | TQFN (ZH32) MSL1 PPF |
Parameters / Models | PI6CG33401CZHIEX | PI6CG33401ZHIEX | PI6CG33401ZHIEX-13R |
Function | Generator | Generator | Generator |
Input Type(s) | HCSL | HCSL | HCSL |
Jitter | 0.05 | 0.05 | 0.05 |
Количество выходов | 4 | 4 | 4 |
Output Frequency | 100 | 100 | 100 |
Output Type(s) | HCSL | HCSL | HCSL |
Skew | 50 | 50 | 50 |
Напряжение питания | 3.3 | 3.3 | 3.3 |
Temperature | -40 to 85 | -40 to 85 | -40 to 85 |
- Connectivity & Timing > Clock ICs > Application Specific Clocks > PCI Express (PCIe) Clock Generators
