Datasheet Diodes PI6CB33402ZHIEX — Даташит
Производитель | Diodes |
Серия | PI6CB33402 |
Модель | PI6CB33402ZHIEX |
Very Low Power 4-OUTPUT Pcie Clock Buffer With On-Chip Termination
Very Low Power 4-Output PCIe Clock Buffer With On-Chip Termination
Купить PI6CB33402ZHIEX на РадиоЛоцман.Цены — от 180 до 24 189 ₽ 13 предложений от 6 поставщиков Clock Fanout Buffer 4-OUT 1-IN 1:4 32-Pin TQFN EP T/R | |||
PI6CB33402ZHIEX-13R Diodes | от 180 ₽ | ||
PI6CB33402ZHIEX Diodes | 263 ₽ | ||
PI6CB33402ZHIEX | 24 189 ₽ | ||
PI6CB33402ZHIEX Diodes | по запросу |
The PI6CB33402 is a 4-output very low power PCIe Gen1/Gen2/ Gen3/Gen4/Gen5 clock buffer.
It takes a reference input to fanout four 100MHz low power differential HCSL outputs with on-chip terminations. The on-chip termination can save 16 external resistors and make layout easier. Individual OE pin for each output provides easier power management.
It uses Diodes proprietary PLL design to achieve very low jitter that meets PCIe Gen1/Gen2/Gen3/Gen4/Gen5 requirements. Other than PCIe 100MHz support, this device also support Ethernet application with 50MHz, 125MHz and 133.33MHz via SMBus. It provides various options such as different slew rate and amplitude through SMBUS so that users can configure the device easily to get the optimized performance for their individual boards.
Корпус | TQFN (ZH32) MSL1 PPF |
Function | Buffer |
Input Type(s) | HCSL |
Jitter | 0.05 |
Количество выходов | 4 |
Output Frequency | 100MHz, 125MHz, 133.33MHz, 156.25MHz |
Output Type(s) | HCSL |
Skew | 50 |
Напряжение питания | 3.3 |
Temperature | - 40 to 85C |
- PI6CB33402ZHIEX
- Connectivity & Timing > Clock ICs > Application Specific Clocks > PCI Express (PCIe) Clock Buffers
