Datasheet Diodes PI6CB33601 — Даташит
Производитель | Diodes |
Серия | PI6CB33601 |
Very Low Power 6-OUTPUT Pcie Clock Buffer With On-Chip Termination
Very Low Power 6-Output PCIe Clock Buffer With On-Chip Termination
Купить PI6CB33601 на РадиоЛоцман.Цены — от 182 до 25 165 ₽ 9 предложений от 5 поставщиков Микросхема: CLOCK BUFFER W-QFN5050-40 | |||
PI6CB33601ZLAIEX Diodes | 182 ₽ | ||
PI6CB33601ZLAIEX Diodes | от 636 ₽ | ||
PI6CB33601ZLAIEX | 25 165 ₽ | ||
PI6CB33601ZLAIEX Diodes | по запросу |
The PI6CB33601 is a 6-output very low power PCIe Gen1/Gen2/ Gen3/Gen4/Gen5 clock buffer.
It takes a reference input to fanout six 100MHz low power differential HCSL outputs with on-chip terminations. The on-chip termination can save 24 external resistors and make layout easier. Individual OE pin for each output provides easier power management.
It uses Diodes proprietary PLL design to achieve very low jitter that meets PCIe Gen1/Gen2/Gen3/Gen4/Gen5 requirements.
Other than PCIe 100MHz support, this device also support Ethernet application with 50MHz, 125MHz and 133.33MHz via SMBus. It provides various options such as different slew rate and amplitude through SMBUS so that users can configure the device easily to get the optimized performance for their individual boards.
PI6CB33601ZLAIEX | |
N | 1 |
Корпус | TQFN (ZLA40) MSL1 |
Parameters / Models | PI6CB33601ZLAIEX |
Function | Buffer |
Input Type(s) | HCSL |
Jitter | 0.05 |
Количество выходов | 6 |
Output Frequency | 100MHz, 125MHz, 133.33MHz, 156.25MHz |
Output Type(s) | HCSL |
Skew | 50 |
Напряжение питания | 3.3 |
Temperature | - 40 to 85C |
- Connectivity & Timing > Clock ICs > Application Specific Clocks > PCI Express (PCIe) Clock Buffers
