Datasheet Diodes PI6CB33201 — Даташит
Производитель | Diodes |
Серия | PI6CB33201 |
Pci Express (pcie) Clock Buffers
Very-Low-Power Two-Output PCIe Clock Buffer With On-Chip Termination
Купить PI6CB33201 на РадиоЛоцман.Цены — от 137 до 20 708 ₽ 14 предложений от 7 поставщиков Микросхема: CLOCK BUFFER,V-QFN4040-24,T&R,3. | |||
PI6CB33201ZDIEX Diodes | 137 ₽ | ||
PI6CB33201ZDIEX Diodes | от 241 ₽ | ||
PI6CB33201ZDIEX | 20 708 ₽ | ||
PI6CB33201ZDIEX Diodes | по запросу |
The PI6CB33201 is a two-output very-low-power PCIe Gen1/ Gen2/Gen3/Gen4/Gen5 clock buffer.
It takes a reference input to
fanout two 100MHz low-power differential HCSL outputs with on-chip terminations. The on-chip termination can save eight
external resistors and make layout easier. Individual OE pin for each output provides easier power management.
It uses Diodes proprietary PLL design to achieve very-low jitter that meets PCIe Gen1/Gen2/Gen3/Gen4/Gen5 requirements.
Other than PCIe 100MHz support, this device also support Ethernet application with 50MHz, 125MHz, and 133.33MHz via
SMBus. It provides various options such as different slew rate and amplitude through SMBUS, so users can configure the device easily to get the optimized performance for their individual boards.
PI6CB33201ZDIEX | PI6CB33201ZDIEX-13R | |
N | 1 | 2 |
Корпус | TQFN (ZD24) MSL1 Sn | TQFN (ZD24) MSL1 Sn |
Parameters / Models | PI6CB33201ZDIEX | PI6CB33201ZDIEX-13R |
Function | Buffer | Buffer |
Input Type(s) | HCSL | HCSL |
Jitter | 0.05 | 0.05 |
Количество выходов | 2 | 2 |
Output Frequency | 100MHz, 125MHz, 133.33MHz, 156.25MHz | 100MHz, 125MHz, 133.33MHz, 156.25MHz |
Output Type(s) | HCSL | HCSL |
Skew | 50 | 50 |
Напряжение питания | 3.3 | 3.3 |
Temperature | - 40 to 85C | - 40 to 85C |
- Connectivity & Timing > Clock ICs > Application Specific Clocks > PCI Express (PCIe) Clock Buffers
