Datasheet Diodes PI6CB332000 — Даташит
Производитель | Diodes |
Серия | PI6CB332000 |
20-OUTPUT Pcie G4 Clock Buffer With On-Chip Termination
Datasheet PI6CB332000
PDF, 1.5 Мб, Язык: анг., Файл закачен: 11 мар 2020, Страниц: 21
20-Output PCIe G4 Clock Buffer With On-Chip Termination
Купить PI6CB332000 на РадиоЛоцман.Цены — от 293 до 33 401 ₽ 10 предложений от 6 поставщиков Микросхема: CLOCK BUFFER V-QFN100100-72 | |||
PI6CB332000ZDIEX Diodes | 293 ₽ | ||
PI6CB332000ZDIEX Diodes | 299 ₽ | ||
PI6CB332000ZDIEX Diodes | от 677 ₽ | ||
PI6CB332000ZDIEX Diodes | по запросу |
The PI6CB332000 is an 20-output very low-power PCIe clock buffer.
It takes an reference input to fanout 20 100MHz low-power differential HCSL outputs with onchip terminations. The on-chip termination can save 80 external resistors and make layout easier. 8 OE pins combined with SMBus register pins for controlling each output provides easier power management.
It uses Diodes' proprietary design to achieve very-low jitter that meets PCIe Gen1/Gen2/Gen3/Gen4/Gen5 requirement.
PI6CB332000ZDIEX | |
N | 1 |
Корпус | TQFN (ZD72) |
Parameters / Models | PI6CB332000ZDIEX |
Function | Buffer |
Input Type(s) | HCSL |
Jitter | 0.03 |
Количество выходов | 20 |
Output Frequency | 100MHz |
Output Type(s) | HCSL |
Skew | 50 |
Напряжение питания | 3.3 |
Temperature | - 40 to 85C |
Серия: PI6CB332000 (1)
- Connectivity & Timing > Clock ICs > Application Specific Clocks > PCI Express (PCIe) Clock Buffers
