Datasheet Cypress CYPD6127-48LQXI — Даташит
Производитель | Cypress |
Серия | CCG6SF |
Модель | CYPD6127-48LQXI |
Dual- Single-Port USB-C Power Delivery
USB Type-C Port Controller
CYPD6127-48LQXIT Infineon | 575 ₽ | ||
CYPD6127-48LQXIT Infineon | по запросу | ||
EZ-PD CCG6DF and EZ-PD CCG6SF are Cypress’ dual-port and single-port USB-C™ and Power Delivery controllers targeting PCs and Notebooks.
CCG6DF/CCG6SF integrates a VBUS provider path load switch controller along with USB authentication support, VBUS-to-CC short protection, VBUS-to-SBU short protection, 20V-VBUS regulator, high-voltage NFET gate drivers for VBUS Consumer path, SBU pass-through and USB HS mux.
CCG6DF/CCG6SF supports Dual Role Port (DRP) and will fully support the Power Delivery 3.0 specification. CCG6DF/CCG6SF is a programmable solution with 64KB flash and 96-KB ROM supporting fail-safe boot up and firmware upgrade.
Product Features
- USB Type-C and Power Delivery 3.0 supporting USB3 and USB4, Thunderbolt, DisplayPort Alternate Mode platforms
- Integrated Digital Blocks
- Two timers, counters, PWMs, and up to 23 GPIOs
- Four SCBs for configurable master/slave I2C, SPI or UART
- Integrated Analog Blocks
- VBUS Provider Load switch (5V/3A)
- Slew rate controlled turn-on on VBUS path
- UAB PD 3.0 Fast Role Swap support
- Integrated high-voltage 20V-regulator
- SBU Pass through, USB analog mux
- VBUS-to-CC short protection
- VBUS-to-SBU short protection
- VCONN FETs
- High-side current sense amplifier across 5 mohms
- High-voltage NFET gate drivers for VBUS consumer path
- VBUS discharge NFET
- System-Level Fault Protection
- Over-current, Over-voltage, Under-volatge, Reverse-current and Short-circuit protection on VBUS provider path
- VCONN over-current protection
- Thermal Shutdown
- Packages: CCG6DF: 96-BGA (6x6 mm) and CCG6SF: 48-QFN (6x6 mm)
- CYPD6127-48LQXI CYPD6127-96BZXI
- USB Controllers > USB-C and Power Delivery
CYPD612748LQXI, CYPD6127 48LQXI
