Datasheet Cypress CCG6SF — Даташит
ПроизводительCypress
СерияCCG6SF
Dual- Single-Port USB-C Power Delivery
Preliminary Datasheet EZ-PD CCG6DF, CCG6SF
PDF, 1.5 Мб, Язык: анг., Файл закачен: 11 мар 2020, Страниц: 50
USB Type-C Port Controller
Критерии выбора литиевых аккумуляторов и батареек: что необходимо учитывать разработчикам
EZ-PD CCG6DF and EZ-PD CCG6SF are Cypress’ dual-port and single-port USB-C™ and Power Delivery controllers targeting PCs and Notebooks.
CCG6DF/CCG6SF integrates a VBUS provider path load switch controller along with USB authentication support, VBUS-to-CC short protection, VBUS-to-SBU short protection, 20V-VBUS regulator, high-voltage NFET gate drivers for VBUS Consumer path, SBU pass-through and USB HS mux.
CCG6DF/CCG6SF supports Dual Role Port (DRP) and will fully support the Power Delivery 3.0 specification. CCG6DF/CCG6SF is a programmable solution with 64KB flash and 96-KB ROM supporting fail-safe boot up and firmware upgrade.
Product Features
  • USB Type-C and Power Delivery 3.0 supporting USB3 and USB4, Thunderbolt, DisplayPort Alternate Mode platforms
  • Integrated Digital Blocks
    • Two timers, counters, PWMs, and up to 23 GPIOs
    • Four SCBs for configurable master/slave I2C, SPI or UART
  • Integrated Analog Blocks
    • VBUS Provider Load switch (5V/3A)
    • Slew rate controlled turn-on on VBUS path
    • UAB PD 3.0 Fast Role Swap support
    • Integrated high-voltage 20V-regulator
    • SBU Pass through, USB analog mux
    • VBUS-to-CC short protection
    • VBUS-to-SBU short protection
    • VCONN FETs
    • High-side current sense amplifier across 5 mohms
    • High-voltage NFET gate drivers for VBUS consumer path
    • VBUS discharge NFET
  • System-Level Fault Protection
    • Over-current, Over-voltage, Under-volatge, Reverse-current and Short-circuit protection on VBUS provider path
    • VCONN over-current protection
    • Thermal Shutdown
  • Packages: CCG6DF: 96-BGA (6x6 mm) and CCG6SF: 48-QFN (6x6 mm)
CCG6DF
Серия: CCG6SF (2)
  • USB Controllers > USB-C and Power Delivery
На английском языке: Datasheet Cypress CCG6SF
